'96 ACCORD MISSES AT IDLE
Old Sep 13, 2004 | 03:04 PM
ram0869's Avatar
Default '96 ACCORD MISSES AT IDLE
my problem started about a week ago, when the car all the sudden misses at idle or when i shift gears an let the rpm's go down the car sometimes stalls. i was told to change the fuel filter. distr. cap and rotor, spark plugs and wires are new. i checked for proper gap was ok. now fuel pressure is ok, vacumm lines r also ok. i recently bought a seafoam additive and pour it in into the throttle like it explains, problem kinda stop but still misses at idle but not when shiftin gears. could it be timing, egr valve or etc... what do u guys think?
Old Sep 13, 2004 | 06:07 PM
daveedd357's Avatar
Default Re: '96 ACCORD MISSES AT IDLE (ram0869)
did you wash the engine. there may be water under the cap.
Old Sep 15, 2004 | 09:41 AM
ram0869's Avatar
Default Re: '96 ACCORD MISSES AT IDLE (daveedd357)
no, i didnt wash the engine. the rotor and distr. cap are brand new........
Old Sep 15, 2004 | 09:52 AM
H2290's Avatar
Your best bet is to take a look at the Helms manual (you do have one, right?) and check the whole EGR system. Also, check idle air control valve and your ignition coil.
Old Sep 16, 2004 | 12:32 PM
ram0869's Avatar
Default Re: '96 ACCORD MISSES AT IDLE (H2290)
yes. i have the manual. i'll check the egr system and the ign.. coil.....
Ceshion
Sep 26, 2025 05:24 AM
shanec80
Mar 19, 2018 04:07 AM
bizmackus
Feb 16, 2007 06:34 PM
dmxsoulja3
12
Nov 16, 2005 12:10 PM
Accord88
Feb 23, 2003 05:53 AM
