1990 Honda accord overheating.
I have a 1990 Accord Ex 5 spd that keeps overheating.
I had the radiator rodded and flushed, there's no themostat in the car the fans run fine so why is it still overheating?
have u checked the water pump? it could also be the ignition timing... also make sure you have 50/50 solution on your cooling system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foxracing27565 »</TD></TR><TR><TD CLASS="quote">I have a 1990 Accord Ex 5 spd that keeps overheating.
I had the radiator rodded and flushed, there's no themostat in the car the fans run fine so why is it still overheating? </TD></TR></TABLE>
Have you bled the air out of the system?
u mean when u driveing, the temperature jump up at the redline suddently right? not going up slowly? if jump up suddent it mean u didn't bled the cooling system right, they still have some air inside. there has a small bleder on the top of the water hose housing relax it and refill the cooling. let see work or not
shawn474
Jul 14, 2014 12:04 PM
kevinp1
Jun 30, 2012 06:47 PM
justhunt87
May 30, 2011 03:07 PM
