Quickest way to replace a clutch?
It's been a couple of weeks since i've gotten my new clutch and still haven't put it in...i'm planning to do it this sunday and i was wondering if you know a good way to put it in; let me rephrase: FASTEST way to do it?
different people tell me different things and i wanted to get all opinions together to let all of us learn
So any know-how or a good procedure will be very helpful
Thanks in advance
Thanks in advance
bring it to your friend who works at a tranny shop. we did mine in 2 hours. but seriously, if you have access to a lift, it will make things MUCH easier
scott
scott
i'd say buddy with lift or send to tranny shop.
Or do a Homer Simpson pull up to a pit lane during nascar and yell hurry hurry new clutch!
Fastest?
Don't expect lightening speeds especially if you haven't done this before.
Take your time and make sure it's done right.
Get a Helms for all the torque specs and full detailed step-by-step instructions.
Plan for a Saturday and part of Sunday just in case you get lazy.
i personally never had done this myself..but i am working with a friend of mine whos done it a few times and i just wanted to know if you guys had any other opinions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
wha!?
wha!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. »</TD></TR><TR><TD CLASS="quote">wha!?</TD></TR></TABLE>
Dont like helms or what....
Yager-
Yager-
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
there you go
Helminc.com
stan
there you go
Helminc.com
stan
your best bet to do it fastest on your own is to...
-break only the lower control arm balljoints
-drain tranny and radiator and remove axles from tranny and let dangle
-loosen the trans bolts
-lift out the entire engine/trans assembly
-set down and pull off trans
-change clutch
-re-install everything in reverse
with handtools it'll take a few hours
with air just a couple hours
IF you DON'T have a hoist, the experienced friend, and a flat surface... take it to someone who does, or it'll be a good day+ job
Modified by MonkeyMagic at 10:02 PM 9/13/2004
-change clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportHatch »</TD></TR><TR><TD CLASS="quote">
Yager-</TD></TR></TABLE>
no, that was in reference to the torque specs...what torque specs?
my first time took me 6 hours with one friend helpin... no hoist, and on a slanted driveway at that.
hardest part was stabbin the tranny back in.
and if you do it w/o a hoist.. dont do it on a slanted driveway. an hour of the work was tryin to get the motormounts lined back up b/c they got all cockeyed from the motor leaning backwards
no, that was in reference to the torque specs...what torque specs?</TD></TR></TABLE>
the torque specs and sequence for the pressure plate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic »</TD></TR><TR><TD CLASS="quote"> your best bet to do it fastest on your own is to...
<U>-lift out the entire engine/trans assembly</U>
-change clutch
Modified by MonkeyMagic at 10:02 PM 9/13/2004</TD></TR></TABLE>
Agreed, I pulled my ZC motor in 2-3hrs, it may take longer but it makes putting the tranny back on and realigning it so much easier. Not to mention torqing the pressure plate bolts, aligning it etc. Its certainly an easy way but not a fast way.
-change clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. »</TD></TR><TR><TD CLASS="quote">interesting, i never really thought about or worried about that before. heh</TD></TR></TABLE>
That's why your tranny bolts are now finger lose after 3,000 miles...
-change clutch
would you disconnect everything from the engine just as if you were doing a swap?
-change clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">i'd say buddy with lift or send to tranny shop.
Or do a Homer Simpson pull up to a pit lane during nascar and yell hurry hurry new clutch!</TD></TR></TABLE>
That was a funny *** episode
i just dropped a tranny out of my 90 si last thursday in a shop with a lift. it took us about 3 hours and that was messing around a little. like a couple beers and what not lol, but yea it not to bad with a lift.
so i got it done, i took out the battery, intake and dropped the tranny, and replace the clutch, and everything went back together....had too much beers while doin it, so it took longer than it should have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven »</TD></TR><TR><TD CLASS="quote">the quickest you'll do it for the first time without a shop or someone who's done it before will take you 4-6hrs.</TD></TR></TABLE>
I doubt that!
I doubt that!
and chips. and take your time.
