O2 sensor on d15 vtec?
Okay I put this motor in my car a while ago and am just now getting the ecu and converting to 0bd1. I was told that I have to have the 4 wire o2 sensor for this but on the manifold that came with the motor there is a 1 wire sensor. Did the people I bought the motor from just switch it or can I run 1 wire?
If you are OBD-1 then you need to match your ECU.
Get the right O@ for your ECU - 4 wire.
The ECU will be looking for the 4 wire for it's heater circuit.
Without it you will get a nice fat ECU code.
but I don't have to switch to obd1 injectors. correct? thats what I heard anyway. I was planning on it though so While the subject is here I read on a write up on here that you just the the Injector box out/off and just soulder all the wires together and then put electrical tape on them is this correct? don't wanna funk up my car because I also heard that if you cut those wires that your car will catch fire.(maybe if they arent souldered correctly or if your supposed to be running with the IB?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 »</TD></TR><TR><TD CLASS="quote">but I don't have to switch to obd1 injectors. correct? thats what I heard anyway. I was planning on it though so While the subject is here I read on a write up on here that you just the the Injector box out/off and just soulder all the wires together and then put electrical tape on them is this correct? don't wanna funk up my car because I also heard that if you cut those wires that your car will catch fire.(maybe if they arent souldered correctly or if your supposed to be running with the IB?</TD></TR></TABLE>
No, you don't have to use OBD-1, OBD-2 injectors. You can use the preOBD ones and keep the injector resistor box.
Since you are going to use the OBD-1 injectors, all you do is cut the green injector resistor box plug off and solder all 5 wires together and tape them up/shink tube them.
cool. I'm trading my obd0 injectors for the obd1 injectors to some guy here were I live so I'm not really losing anything. I'm also getting the clips.
Also on the obd1 cars the ecu light is in the dash or somthing correct? I know there isn't one in the ecu so how do I check the codes? or were do I wire a a little light up to on the ecu if you can?
FUP23
Aug 16, 2002 08:16 AM
