tein
Guest
Posts: n/a
hey guys, i am bout to purchase the tein ra's and was wondering where can i find out the perfect settings for em? my friend has the SS"s on this rsx and he has been having trouble finding the right settings for them for quite some time now. any suggestions or advice?
in my oppinion, every car is going to be different...and there is no perfect setting.. because if there was a perfect setting, why need to have them be adjustable.. they could just sell them all with the perfect settings... it's just test and tune, and a setting that you feel comfortable with....there should be a standard setting and you have to work from there to get what you want..
theres a couple different ways. The way people adjust wings is they take the car out for a lap and try to anticipate when over steer will occur on the turns. You then adjust the wing accordingly.
As far as suspension, u can do it the same method. Start by setting everything on the hardest. Then just adjust a pair softer and softer until u get what you want.
is that on any specific strut tho? Do they equipt alltheir adjustable struts with the same number of notches? I've only had expirience with my HAs as far as Tein goes.
Here is the setup that they recommend, it shows all the different springs and coilovers: http://tein.com/ti/a58.html
And here are the instruction manual for the Tein RA coilovers for the S2000: http://tein.com/ti/inst/ph64u.pdf
I'm not sure if all the Tein models have the same number of dampening adjustability, but most the Tein coilovers are 16-way adjustable. For the RA's they recommend 10clicks back from the hardest setting in the front and 6clicks back from the hardest setting in the rear.
P.S. All this stuff is listed on the Tein website under Technical Information
who here can read japanese? my coilovers are JDM, they rn't made for the S13 here in the US so i have to read the Jspec version
http://www.tein.co.jp/ti/hr/hn20.pdf
can someone tell me the specs for the HA coilovers for 89-98 180SX?
Put it this way, both JIC and Tein produce good products and are used for professional road racing, drifting, autox, etc. Get whichever you get a better deal on or if you just simply want a certain brand.
