vtec help
i have a b16b CTR motor in a 98 cx..and my vtec doenst work...here is what i have done to fix it..oil level is fine..JDM motors dont run on oil pressure for vtec...check engine lights on....tryed to obd2 scanner..scanner wont read ECU..and nothing else woeks now i am lost now...any suggettions on whats going on here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9civicJDM »</TD></TR><TR><TD CLASS="quote">i have a b16b CTR motor in a 98 cx..and my vtec doesn't work...here is what i have done to fix it..oil level is fine..JDM motors don't run on oil pressure for vtec...check engine lights on....try ed to obd2 scanner..scanner wont read ECU..and nothing else works now i am lost now...any suggestions on whats going on here</TD></TR></TABLE>
What do you mean Jdm motors do not work on oil pressure. Yes they do need oil pressure. The oil pressure is what pushes in the pin to let the vtec lobe on the cam to work. Jdm and Usdm motors vtec system were not made differently. you said that you hooked up a scanner to read your code and that it was not working. My question is did you hook up your scanner correctly and is your scanner working. You might want to try hooking up the paper clip and checking the codes manually on the dash with the amount of times the check light flashes and then looking up the code. Reasons for vtec not to work are, Incorrect wiring, oil pressure, oil level, oil pressure sending unit, oil pressure switch, incorrect timing , oil temp, vtec solenoid malfunction, a clog in the solenoid screen. knock sensor, Vss , and sometimes the o2 sensor on obd2 cars can affect it. My motor about a year go quit activating vtec , i could not figure it out try ed everything, finally i tore the head app-art and it turned out i had a clog in one of the oil chambers and was not creating enough pressure,
vtecn8ive
22
Aug 3, 2005 01:06 PM
Nextelbuddy
Apr 30, 2003 01:42 PM
