putting a civic radiator in a 95 Integra GSR
Old Sep 13, 2004 | 07:27 AM
k_bster24's Avatar
Default putting a civic radiator in a 95 Integra GSR
Was just wandering how hard it would be to get an aftermarket civic radiator and put it in my 95 Integra GSR to free up some room. Is that a smart thing to do or will my car run hot if i have that small of a radiator.
Thanks
Old Sep 13, 2004 | 07:58 AM
ihaterice's Avatar
Default Re: putting a civic radiator in a 95 Integra GSR (k_bster24)
you shouldn't have any issues with overheating at all - pretty easy to do actually - just have to make custom mounting brackets for it to fit correctly and then run the coolant hoses
james innes
Old Sep 13, 2004 | 09:06 AM
Doctor CorteZ's Avatar
why would you want to downgrade your cooling system ?
Old Oct 13, 2004 | 10:35 PM
B00ST2nR's Avatar
Default Re: putting a civic radiator in a 95 Integra GSR (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to downgrade your cooling system ? </TD></TR></TABLE>
A Civic (Halfcore) Fluidyne or Koyo radiator will actually cool better than the stock Integra Radiator. It won't be downgrading.
Old Oct 13, 2004 | 10:58 PM
eg_type_r93's Avatar
Default Re: putting a civic radiator in a 95 Integra GSR (B00ST2nR)
its real easy to do anyone can do it i put a teg rad in my hb totally easy
Old Oct 13, 2004 | 11:37 PM
ToddZILLAinLA's Avatar
Why would you call it a downgrade? Depending on what you use the car for should matter on Radiator Size on my LS/VTEC i put a CX 5spped Radiator its the smallest from all the Hondas and it carry's the less amount of water which also means less weight and faster circulation
str8JDMteggy
Feb 14, 2007 10:07 AM
jolt-tsp
Apr 26, 2005 06:09 AM
SilverGSR99
Jun 21, 2004 09:19 PM
user 996328629
Feb 1, 2004 07:23 PM
revhigh89
Jan 21, 2004 02:10 PM
