Apex'i N1 without pillow ball mounts?
Old Sep 13, 2004 | 06:56 AM
Andre's Avatar
Default Apex'i N1 without pillow ball mounts?
I have bougt a set of 99 spec Apex'i N1 dampers and they came without the pillow ball mounts. I only got these 'rings' which came on the top and the bottom of each spring.
Somebody on HT told me i can not use the N1 without the pillow ball mounts. Is he right?
Old Sep 13, 2004 | 07:18 AM
BolivianDc2's Avatar
Default Re: Apex'i N1 without pillow ball mounts? (Andre)
no, you could use them.
Old Sep 13, 2004 | 08:07 AM
georgiajdm's Avatar
on double wishbone it doesn't matter, you can use oem rubber upper mounts (nice b/c you don't get too much vibration).. the aftermarket just adds rigidity and feel by providing a solid mounting pt.
on mac struts you get added camber plates which is nice but that isn't possible with d/w suspension
Old Sep 13, 2004 | 03:15 PM
ITR-00-1457's Avatar
I run the N1 99spec on my R with the factory upper hats and it is great. The ride with the poly ones is much different, alot harsher.
Old Sep 13, 2004 | 06:55 PM
Black R's Avatar
25 Year Member
I have the 99 spec apexi n1 dampers on my 00 itr as well.
If anyone wants to sell some of the springs off of their set, please IM me.
The ride is and much more responsive than with the stock rubber upper mounts. If you track or autox your car, get the pillowball uppers. I would NEVER use the stock rubber upper mounts. AND the apexi springs are much smaller in diameter than the stock ones. So the apexi springs will slide around inside the stock rubber uppers.
I have an extra set of the pillowball mount uppers if anyone wants to buy them as well...
Old Sep 13, 2004 | 07:07 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Apex'i N1 without pillow ball mounts? (Black R)
Pillow ball mounts are a MUST have IMO.
Old Sep 13, 2004 | 07:13 PM
georgiajdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I
there's an aluminum top hat in between the spring and stock upper mount, there's no movement jimmy fallon..learn your chit
Old Sep 13, 2004 | 07:30 PM
Black R's Avatar
25 Year Member
Default Re: Apex'i N1 without pillow ball mounts? (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">
there's an aluminum top hat in between the spring and stock upper mount, there's no movement jimmy fallon..learn your chit</TD></TR></TABLE>
I have them, and with stock upper mounts they = dookie.
Khoi, stick with your taiwanese sweat-shop tanabe "coil-overs."
Don't make me post the pic of your *** bending over...
Old Sep 13, 2004 | 08:28 PM
BenB's Avatar
Don't make me post the pic of your *** bending over... </TD></TR></TABLE>
LOL. Lemme find that pic...
Old Sep 13, 2004 | 08:44 PM
Kicker773's Avatar
Default Re: Apex'i N1 without pillow ball mounts? (BenB)
oh crap so the one's i ordered won't come with pillow mounts.. chet
Old Oct 27, 2004 | 11:29 AM
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I have an extra set of the pillowball mount uppers if anyone wants to buy them as well... </TD></TR></TABLE>
I have received the pillow ball mounts from Black R today and while i have cleaned them i have noticed that i can spin only 2 spherical bearings. Is this ok? Are the rear ones (?) fixed?
They haven't been used for a while and it is very hard to spin the bearings, do i have to grease them?
Old Oct 28, 2004 | 12:40 AM
Andre's Avatar
Bump for a reply, would like to install the coilovers tomorrow.
Old Oct 29, 2004 | 12:53 PM
SOUNDEFFECTS's Avatar
The bearings will move when you install them, mine were very tight as well til I put them in..Don't worry they be fine.
Old Oct 29, 2004 | 01:23 PM
Andre's Avatar
Default Re: Apex'i N1 without pillow ball mounts? (SOUNDEFFECTS)
Thanks for your reply. I bought some WD-40 yesterday and the result is that the two bearings i could spin/rotate/wobble before now can be spinned very easy by hand and the other two still seems to be rigid.
I'm afraid they will damage the shafts of the damper if i install them
yellow blur
May 13, 2005 11:48 PM
yellow blur
Feb 26, 2004 08:20 AM
colt45.5
Jan 18, 2004 08:28 AM
743power
Jun 22, 2003 08:47 PM
