B-series Swap W/AC
Old Sep 13, 2004 | 06:08 AM
sooboss's Avatar
Default B-series Swap W/AC
My HB has no AC. When I did my swap most of the AC was junk so I Trashed it. Now Iam considering it. Re-installing it. I know that. I need Hasports Bracket for the B-series swap. But god i look in the engine bay and seems there isn't too much room for this mod. well Iam going to go through with it just wanted to know if anyone has done this and if they have pictures of it...
Old Sep 13, 2004 | 07:12 AM
coma-b16's Avatar
Default Re: B-series Swap W/AC (sooboss)
I have an ac compressor if you want to buy it.
Old Sep 13, 2004 | 07:19 AM
sooboss's Avatar
Default Re: B-series Swap W/AC (coma-b16)
do you have all the other hardware. lines, condensor... etc...
Will the condensor fit.??? my biggest question...
Old Sep 13, 2004 | 07:26 AM
coma-b16's Avatar
I cant im I am a new user but all i have is the compressor and a couple of the lines. Everything else was sold already and yes it does work fine and properly.
Old Sep 13, 2004 | 07:44 AM
sooboss's Avatar
so what do you want for it??? price..
Old Sep 13, 2004 | 08:07 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I have a/c on mine..
I used the bracket from the b-16 and
modified it to work with the Sanden compressor.
I had to make a dent in the crossmember and in front of the pulley
to get it to clear..
I have both fans in place with only a small piece of the shroud unbolted/removed
on the drivers side unit..It was tight,but it all fit and works great..
Old Sep 13, 2004 | 08:34 AM
sooboss's Avatar
Default Re: B-series Swap W/AC (88DXCRX)
Looks good. I am going to start my installation. Just need some parts now..
Old Sep 13, 2004 | 08:41 AM
crx_88_si's Avatar
i heard a delsol vtec ac bracket works w/ d-series compressors and bseries motors.. any one confirm?
Old Sep 13, 2004 | 08:46 AM
sooboss's Avatar
Default Re: (crx_88_si)
god if that works... Iam in buisness....
Old Sep 13, 2004 | 09:21 AM
sooboss's Avatar
Default Re: (sooboss)
And what belt do i use?
Old Sep 13, 2004 | 09:22 AM
sooboss's Avatar
nevermind i see the numbers...
crx_88_si's Avatar
i dunno.. maybe a delsol vtec belt? i would get 3 and return the 2 that dont work
del sol vtec
crx si
maybe a 90-93 gsr ?
again im not sure if the bracket works or not though.
Old Sep 13, 2004 | 10:08 AM
slowpokesi's Avatar
i have prett much everything you need minust the condensor, i have one but i wont be able to take it out for a while, but i have all the lines, the evaporator all, compressor, all that stuff,
A new compressor all by itself is like 200+ so id probably want 100 plus shipping for everything, itd have to come in 2 diffrent boxes because the weight of the compressor would smash the lines. The compressor worked before i did my swap and took it out, so it should work without any problems.
Let me know if your intrested, if so i will snap pics.
Old Sep 13, 2004 | 10:29 AM
Jonathan_ED3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">i heard a delsol vtec ac bracket works w/ d-series compressors and bseries motors.. any one confirm?</TD></TR></TABLE>
Yes, that is excatly what EF/B series guys need.
P-54 is what the bracket will be stamped.
As far as the belt, just get a rough measurement of the total distance (after the comp is installed), note the number of ribs and go take a look at the parts store.
Old Sep 13, 2004 | 10:52 AM
88DXCRX's Avatar
I used the same belt for the alternator also.. NAPA part # 25-040300
Old Sep 13, 2004 | 11:11 AM
sooboss's Avatar
Default Re: (Jonathan_ED3)
so that bracket will work...
Old Sep 13, 2004 | 11:32 AM
Yes, it's exactly what you want. You can sometimes find it used (relatively hard to find) , but I got mine brand new from the Honda dealer for around $100.
Old Sep 13, 2004 | 11:36 AM
92jdmhatch's Avatar
i have all the ac parts for sale..the fan..compressor...lines...the lil reservoir thing to refill....i even have nuts and bolts...and it worked fine but i did a swap and didnt want it anymore...let me know if interested
Old Sep 13, 2004 | 12:11 PM
sooboss's Avatar
Default Re: (92jdmhatch)
now i gotta find a bracket...
Old Sep 13, 2004 | 12:53 PM
boomslang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooboss &raquo;</TD></TR><TR><TD CLASS="quote">now i gotta find a bracket...</TD></TR></TABLE>
You can also use a 1997 CRV AC bracket (Honda part # 38930-P7J-000). I have one on my ITR swapped hatch with a 92-95 Civic AC compressor.
It's cheaper than the P54 Del Sol bracket and works the same.
If you want a P54 bracket, I have one for sale here....
https://honda-tech.com/zerothread?id=988491
Old Sep 13, 2004 | 02:13 PM
SqueezinEF's Avatar
Default Re: (boomslang)
I just removed all my AC a couple weeks ago. I have everything...I mean everything...even the Hasport bracket. Let me know. I am in San Diego so you can pick up anytime.
BTW, it's all from an 89 Civic Si HB.
ThatsTheTruth
Jun 6, 2006 04:39 PM
botlebruiser
Mar 7, 2006 08:57 PM
Vt3c_eg
Feb 16, 2006 11:15 AM
