code 4 crank angle
I have sohc vtec in my 88 dx, and throwing code4. I change distributors, swapped wires, redid the connections, and still won't rev pass 3200rpm some one please HELP.
pull the c1-c2 wires again and squeeze the connector that goes over the pin. sometimes when you pull them out they will stretch and not make full contact.
that was my problem with my buddys car.
I changed the distributor to a used jdm one and still doesn't work. I'm probably going to rerun the wires tomorrow with some brand new one and not one from a wire harness. I also will be redoing the timing belt tomorrow too. I let you guys know the outcome.
im pretty sure i know what your problem is you have your crank angle wires in the wrong part on your plug i bet you have them in b11 and b9 if so there upside down and not getting any signal to the crank make sure there in b12 and b10!!!!!!!!!!!!!!!!!!!
brent
brent
Isn't the wires supposed to be in pins c1 and c2. The motor did rev up like two great times which lasted like less than 24 hours with the way the wires are now, so i don't think that is the problem.
Did anyone ever find out what the problem was to this senario??? I have a 91 civic si with a d16z6 Swap. I'm running the 91 (D16a6 dizzy,ECU,injectors, and the ignitor box). When I first drive the car the thing zips around great, once the engine reaches a normal temp I have the same problem mentioned with the studdering at 3200 RPM's. Any and all help will be appreciated!
I have a d15z1 block with d15b2 pistons, d16z6 head, d15z1 ditributor, a p06 ecu d16z6 injectors. I'm running obd-1, I heard that it supposed to be safer, or something like that.
civicb1812345
17
Aug 21, 2013 09:37 PM
monster d
Jun 12, 2013 10:20 PM
hondatuner77
Aug 8, 2010 09:21 AM
crxfreak1117
Nov 28, 2007 05:56 AM
Hcivic88
17
Apr 27, 2004 09:23 PM
... bump
