TPS sensor & Apexi VAFC
Old Dec 8, 2001 | 05:16 PM
S&P500ITR's Avatar
New User
Default TPS sensor & Apexi VAFC
I recently had my throttle body bored. The TPS sensor had to be removed for this procedure and I was told that it would be put back in the exact same position. I was wondering if this could somehow be verified by my VAFC since it picks up various throttle positions and displays them in voltages and in what percentage the throttle is open. I, unfortunatley, did not get a reading before the TB was bored as the vafc was installed after the fact.
[Modified by S&P500ITR, 7:09 PM 12/8/2001]
Old Dec 8, 2001 | 05:51 PM
non-VTEC's Avatar
Default Re: TPS sensor & Apexi VAFC (S&P500ITR)
look at the sensor voltage when the throttle is closed and write it down........and then compare it to the voltage readings after you get the T/B back......
it's should be under settings/sensor check on the V-AFC diplay.......
LUDExCONDUCT
Apr 15, 2004 09:53 AM
redlinegsr
Dec 6, 2002 11:32 AM
Art Vandeleigh
Oct 26, 2002 09:14 PM
CPR
Sep 3, 2002 06:26 AM
