my current all motor #'s
Old Sep 12, 2004 | 10:24 PM
fuccarlos's Avatar
Default my current all motor #'s
well spent some time on the dyno last night and came up with some pretty good #'s w/91 octane gas
current steup is,
b18c1 w/ a.e.b.s. t-sleeves
86mm ross pistons 12.5:1 compession
manley rods
a.e.b.s. main/head studs
b16 head with stage 7 d.p.r. port work
welded and reshaped chambers
ferrerra valves
dpr valve springs w/ crower retainers
crower custum ground camshafts
hytech header (thick tubing)
toda cam gears/toda timing belt
rc 440cc injectors
ericks racing 72mm throttle body
type r mainfold port matched to head
toda flywheel
msd digital 7
wahlbro 255 fuel pump
cometic head gasket
hondata intake manifold gasket
hondata s200
p28 ecu
93 gsr cable tranny
xs fuel pressure reguator
pro drive oil pump gear
moroso oil pan
Old Sep 12, 2004 | 10:45 PM
yeegsr's Avatar
Default Re: my current all motor #'s (fuccarlos)
sweeeeeeetttttttttt number, give it some more octanneeeeee....got ur 1/4 time yet?
Old Sep 13, 2004 | 12:51 AM
OLM-02R's Avatar
faaaaaaaaaarkkkkkk niceeeeeeeeee # dude...post some pics on the build dooood...
Old Sep 13, 2004 | 01:12 AM
fuccarlos's Avatar
Default Re: my current all motor #'s (yeegsr)
no 1/4 mile time yet. with old setup (b-20) it went 12.3 @115 with juice
Old Sep 13, 2004 | 04:53 AM
Idiotboy's Avatar
Nice set up man, those are some nice numbers. Good work!
Old Sep 13, 2004 | 04:56 AM
Tbone's Avatar
Nice build up man..
Looks almost exactly like my 1st 2.0 with my Dpr head..
b18 ge sleeved 84mm
dpr stage 6 head
smsp header
toda b cams
This was only fuel tunned not timming..
Old Sep 13, 2004 | 05:05 AM
BERT-O's Avatar
What cams are you running?
I like how your torque stands throughout the whole RPM. I wonder if has anything to do with the Hytech header
Old Sep 13, 2004 | 06:47 AM
EKhatch's Avatar
Default Re: my current all motor #'s (BERT-O)
Very nice numbers. I just don't understand why DPR has so many stages of headwork?
Old Sep 13, 2004 | 07:05 AM
JDM2ndGen's Avatar
Default Re: my current all motor #'s (EKhatch)
nice numbers
Old Sep 13, 2004 | 07:59 AM
GiT LaO'd's Avatar
Very Nice numbers...Can't wait...
Old Sep 13, 2004 | 08:31 AM
TYPERman2001's Avatar
* B A N N E D *
Default Re: (jaybee)
shoudl of gotten a k series would of gotten 220 to the wheels with jsut bolt ons
Old Sep 13, 2004 | 09:03 AM
ChaseIntegra's Avatar
Default Re: (TYPERman2001)
not everyone is into the whole K-series ****. In older model cars like my 92 Integra, the only option I have is to run a B. Great numbers btw.
Old Sep 13, 2004 | 09:08 AM
justBLZE's Avatar
Chopper 2 Hopper
Nice numbers.
Old Sep 13, 2004 | 09:18 AM
Greenery18's Avatar
Default Re: my current all motor #'s (tommy69)
Those are some sweet numbers, especially the torque. You are making fat torque from down low, and your graph is super steady.... good ****. You say you have custom grind camshafts... can you give us more info on those?
Also, what is that break in the graph in the upper rpms?
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPERman2001 &raquo;</TD></TR><TR><TD CLASS="quote">shoudl of gotten a k series would of gotten 220 to the wheels with jsut bolt ons </TD></TR></TABLE>
Or he could have boosted it and made alot more power - To each is own, power is power no matter how you make it or what you use to make it. Good job once again
Old Sep 13, 2004 | 11:32 AM
tnsxsear1's Avatar
Default Re: (HybridHatch88)
you gonna run it here on the 25th in El Paso at DragFest?
Old Sep 13, 2004 | 11:40 AM
fuccarlos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPERman2001 &raquo;</TD></TR><TR><TD CLASS="quote">shoudl of gotten a k series would of gotten 220 to the wheels with jsut bolt ons </TD></TR></TABLE> i drive a crx and its a daily driver k series is way to much for me ill stick to b series
Old Sep 13, 2004 | 11:41 AM
fuccarlos's Avatar
Default Re: (tnsxsear1)
ill be there for sure
Old Sep 13, 2004 | 11:44 AM
fuccarlos's Avatar
Default Re: my current all motor #'s (Greenery18)
that break in the upper rpms is the tach pickup for the dyno it has a mind of its own sometimes
Old Sep 13, 2004 | 12:42 PM
CHEETAH's Avatar
nice dyno, how much timing you pushing ?
greg
Old Sep 13, 2004 | 01:22 PM
na200whp's Avatar
nice #'s
quick question for comparison. ive got my dyno posted in the link in my sig. our setups are some what similar . my engine has more mid range up to 7500 but after that he kicks my *** to 8000. if these engines were in the same car how would they far at the track?
i hope im not hijacking your thead. if so ill delete.
JCushing's Avatar
the tq curve on that motor is nuts! 136tq + from 3500 to 6k and a steady 148 from 6k to 8k... thats beyond nice right there!
Old Sep 13, 2004 | 01:52 PM
Big Teggie's Avatar
Looks good
Old Sep 13, 2004 | 02:17 PM
fuccarlos's Avatar
Default Re: my current all motor #'s (Tbone)
my 440's on that run were maxed at 93% duty cycle im getting 550's today and c-12 racegas looking to get 235 to 245 whp i havent even touched the extended revs portion of the hondata map so we'll see i know theres more there
Old Sep 13, 2004 | 03:48 PM
AzG35's Avatar
Might I say that this car sounds like a gawddammed funny car when it flys by my house at midnight.
