question: hasport header for EF civic/crx
Old Sep 12, 2004 | 07:11 PM
JhorickJFL's Avatar
Default question: hasport header for EF civic/crx
will this fit on my lsvtec??? cause i know a regular b16 won't clear the block
Old Sep 12, 2004 | 07:21 PM
EVOLUTIONINNYC's Avatar
has port makes a header?
Old Sep 12, 2004 | 07:23 PM
JhorickJFL's Avatar
Default Re: (SiRhatchalot)
yup
Old Sep 12, 2004 | 07:25 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (JhorickJFL)
I had problems with the ITR 4-1 with my LSVTEC... I had to modify the oil pan for the header to fit with enough header to oil pan clearance.
Old Sep 12, 2004 | 07:42 PM
JhorickJFL's Avatar
Default Re: (LSVTEC 91 Civic)
how exactly did you modify it??? any pics?
Old Sep 12, 2004 | 08:19 PM
EL Vap133's Avatar
Default Re: question: hasport header for EF civic/crx (JhorickJFL)
Have you asked Hasport?
Old Sep 12, 2004 | 10:24 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I had problems with the ITR 4-1 with my LSVTEC... I had to modify the oil pan for the header to fit with enough header to oil pan clearance.</TD></TR></TABLE>
Just wondering how you modified the oil pan ? As far as the header goes, I'm gonna say ask hasport but I'm gonna say it will not work. The ls engine is taller and if hasport made the header strictly for the b16, there not gonna make it really long, there gonna make it so it just clears the oil pan on a b16 engine, but IM Brian G on here, he will take care of you.
https://honda-tech.com/zero...00195
Old Sep 12, 2004 | 10:46 PM
608 Gangsta's Avatar
Default Re: (90blackcrx)
i have an LSVTEC with the DC 4-1 header mine barley cleared the oil pan but had to modify front CM heres the pic
Modified by LsFrnknstn at 4:33 AM 9/17/2004
Old Sep 12, 2004 | 10:54 PM
JhorickJFL's Avatar
thanks i pm'd him....good stuff....he's the owner
hasport products are awsome. i use their mounts!
Old Sep 13, 2004 | 04:01 AM
Keebler's Avatar
They are also very expensive.
Old Sep 13, 2004 | 07:38 AM
rsbad454's Avatar
Default Re: (Keebler)
it says right on their website the header is for 88-91 civic's with B16 swap...hello
Old Sep 13, 2004 | 09:31 AM
crx_88_si's Avatar
Default Re: (rsbad454)
the whole "hasport header" is the o2 bungs. thats it.
Old Sep 13, 2004 | 10:09 AM
Rywire's Avatar
Default Re: (crx_88_si)
Are you going to be runnng the dual o2s for a obdo setup? If not dont get that header. I bet it will "fit" , because I am using a dc 4-2-1 header from a 99-00 civic si with no problems.
Ryan
Old Sep 13, 2004 | 10:10 AM
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Are you going to be runnng the dual o2s for a obdo setup? If not dont get that header. I bet it will "fit" , because I am using a dc 4-2-1 header from a 99-00 civic si with no problems.
Ryan</TD></TR></TABLE>
But the civic si comes with the b16 which is a shorter engine compared to the ls/vtec set up.
Old Sep 13, 2004 | 10:16 AM
Rywire's Avatar
Ya, but I run a gsr engine which is the same height as a ls/vtec setup.
Ryan
Old Sep 13, 2004 | 06:48 PM
JhorickJFL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">it says right on their website the header is for 88-91 civic's with B16 swap...hello</TD></TR></TABLE>
yeah i'know it's for the b16 but i want one that already has the holes for the o2 sensors, no biggie. but if there's a way to get it on then i'd take it, unless there's an acception???? mugen????
Old Sep 13, 2004 | 07:42 PM
daidilus's Avatar
yeap all you have to do is take it to a local exhaust shop, and have em weld the bungs in the right places
Old Sep 14, 2004 | 12:07 AM
rjay8604's Avatar
Default Re: (daidilus)
if it fits, i'd probably get it, hasport makes good ****, and you don't have to worry about making sure you weld the o2 bungs in the right place where they might hit the block or you can't get to em.
Old Sep 15, 2004 | 07:29 PM
brian g's Avatar
Default Re: (rjay8604)
It was not designed to fit either the GSR or LSVTEC, but I'll check tomorrow for you guys.
brian g
Old Oct 17, 2004 | 03:11 PM
ef92b's Avatar
Default Re: (brian g)
any news about this? your reply is very much appreciated.
Old Oct 18, 2004 | 07:50 AM
JhorickJFL's Avatar
Default Re: (ef92b)
it doesn't fit
but still looking for any aftermarket header with the o2 sensors in the right spot.
Old Oct 18, 2004 | 08:20 AM
crxkane's Avatar
good luck with that, your best bet is to get one for an ls or a other b18*** blocked motor and just weld the bungs, that is what i did for my lsvtec. ls header and plugged the O2 sensor bung at the colector, that is until obd1 is ready and then the 4 wire O2 will go in.
chadleehonda
Oct 4, 2010 09:37 AM
slow91crx
29
Jun 12, 2006 01:53 PM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
ItrpwrdCrx
Sep 9, 2005 02:47 PM
c.dub
May 13, 2005 06:10 PM
