problem after changing head
Old Sep 12, 2004 | 06:34 PM
erebunicrx's Avatar
Default problem after changing head
ok i just changed my head on my ls motor. i have a 90 ls and just put a 05 head on it. before i put the head on it tha comp was 185 across the cylinders. now its
170, 140, 125, 170. then i put oil in the cyl that read 125 and jumped to 160! so i dont know how the compression dropped so much. any ideas? thanks. -Dale-
Old Sep 12, 2004 | 08:44 PM
acurasolution's Avatar
Default Re: problem after changing head (erebunicrx)
leak down test is the best indication of internal condition...good luck man
Old Sep 12, 2004 | 09:29 PM
rev-speed's Avatar
double check ur timing u may be a tooth off or more.
by the way did u really mean o5 as in 2005?
Old Sep 13, 2004 | 03:51 AM
erebunicrx's Avatar
Default Re: problem after changing head (4cylinder)
opps. no i meant a 95
Old Sep 13, 2004 | 10:22 PM
rev-speed's Avatar
double check ur gauge before u pull that head.
try another gauge or try it on other cars
mannydhanju
Mar 8, 2009 04:12 PM
integragater
Jan 17, 2007 03:14 AM
dat_flip
Jan 23, 2005 10:50 AM
hotintegranights
Jan 4, 2003 11:40 AM
z crx z vtec z
Mar 11, 2002 10:43 PM
