Identifying parts, and wiring questions for b16a.....
Old Sep 12, 2004 | 06:03 PM
DeKaP's Avatar
Default Identifying parts, and wiring questions for b16a.....
If pics dont work, right click and show picture
where do i add the wire to run to the ecu for oil pressure switch?
where do i add the wire to run to the ecu for the 2nd o2 sensor?
Which one is the VTEC solenoid, and where does the wire go exactly to run to the ecu?
Where do i add the wire for the knock sensor to run to the ECU?
vivid details would help if possible
Old Sep 12, 2004 | 06:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Identifying parts, and wiring questions for b16a..... (DeKaP)
Old Sep 12, 2004 | 06:13 PM
DeKaP's Avatar
Default Re: Identifying parts, and wiring questions for b16a..... (88DXCRX)
yea i have that pic as well, i know where it goes into the ecu, i dont know where i install the new wires for each though
Old Sep 12, 2004 | 06:24 PM
88DXCRX's Avatar
white wire in the first pic is the pressure switch goes to b5
the black wire is a ground,ground it at the thermostat housing..
vtec solenoid is the big round thing.wire goes to A8
knock sensor goes to b19
The red dot represents the wire the pic to the right shows the actual location at the plugs..
The O2 sensor question was answered here: http://crx.honda-perf.org/foru...=5641
Also look here for links I posted: https://honda-tech.com/zerothread?id=637661
Here are some good B-16 links:
http://www.geocities.com/dropp...p.htm
http://www.phatwhippincrx.20m.com/custom.html
http://tjshondas.20m.com/b16ainstall.html
http://www.customcivics.com/~brandon/
http://www32.brinkster.com/tjshondas/default.htm
Old Sep 12, 2004 | 06:26 PM
BlueShadow's Avatar
This is your VTEC oil pressure switch (B5).
This is your VTEC solenoid assembly. The grey cylinder circled in yellow is part of the VTEC solenoid. The one wire coming out from under it is your VTEC solenoid wire (A8). The part circled in red is a cam cap bolt (dont remove it), the part circled in blue is a finger.
Knock sensor (B19)
Cant make it out, need a wider angle shot.
Old Sep 12, 2004 | 06:37 PM
DeKaP's Avatar
Default Re: Identifying parts, and wiring questions for b16a..... (BlueShadow)
where exactly is the knock sensor? near where?
Old Sep 12, 2004 | 06:39 PM
DeKaP's Avatar
also what gauge wires do i need? and about how long will i need of each color?
Old Sep 12, 2004 | 06:41 PM
88DXCRX's Avatar
on the back of the engine..see that blue round thing? it is the oil filter..
Old Sep 12, 2004 | 06:43 PM
DeKaP's Avatar
heh im dumb, im tryna do this myself but i dont know nothing about technical stuff...so im just makin sure i know everything before i start ****** up
Old Sep 12, 2004 | 06:44 PM
honda06si's Avatar
i used 18 gauge wire and bought 30 feet and it was enough..was like $5
Old Sep 12, 2004 | 06:46 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeKaP &raquo;</TD></TR><TR><TD CLASS="quote">where exactly is the knock sensor? near where? </TD></TR></TABLE>
inside the red circle...
Old Sep 12, 2004 | 06:48 PM
88DXCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeKaP &raquo;</TD></TR><TR><TD CLASS="quote">heh im dumb, im tryna do this myself but i dont know nothing about technical stuff...so im just makin sure i know everything before i start ****** up</TD></TR></TABLE>
No big deal.. the wiring was the part that frustrated me also..
Just make sure you hook up the o2 sensors like:
or it will run like crap..
SEA Hag's Avatar
20 gauge and 100 ft each of red white and blue...
Just use common sense and measure for yourself. How much wire u use depends on how you choose to go about getting the wire from a to b...
Old Sep 12, 2004 | 06:49 PM
DeKaP's Avatar
Default Re: Identifying parts, and wiring questions for b16a..... (honda90si)
so you could really use any gauge wire if you wanted? its just personal preference?
Old Sep 12, 2004 | 06:51 PM
SEA Hag's Avatar
Use whatever gauge is closest to stock, it varies.
integrawow
Nov 6, 2006 08:00 PM
mengy007
Sep 6, 2004 03:06 PM
StupidSlowRSX
May 11, 2004 06:11 PM
SteelCityKid
Apr 20, 2002 08:28 AM
