made 192.6 hp and 123.2 tq. second trip but with a Field controller
Old Dec 8, 2001 | 02:58 PM
TypeR76's Avatar
Default made 192.6 hp and 123.2 tq. second trip but with a Field controller
Here are my mods:
Hytech header
5Zigen axle-back
Field vtec controller
test pipe
JUN III set-up
stock compression. a Yoshio-reprogrammed computer ,comptech Icebox with K&N(stock elbow)
I made192.6 HP and 123.2 TQ
cam gears set zero
I adjusted VTEC point and fuel
I need suggestions on next mods
Old Dec 8, 2001 | 03:01 PM
Black SVT's Avatar
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (TypeR76)
Do you still have the stock b-pipe?
Old Dec 8, 2001 | 03:02 PM
TypeR76's Avatar
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (Dc2k-specR)
Yes, I do
Old Dec 8, 2001 | 03:07 PM
FSTASNTZ's Avatar
Why did you not adjust the cam gears? What does the plot and mixture look like?
Jason
Old Dec 8, 2001 | 03:15 PM
TypeR76's Avatar
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (FSTASNTZ)
I didn't have time to remove the belt cover off and A/F ratio was between 13.8 and 13.1 to 1 but when VTEC kicks in it leaned all the way up to 14.8.
Old Dec 8, 2001 | 03:21 PM
FSTASNTZ's Avatar
14.8 is a little on the lean side from my tuning experience. 13.1 is where most of the Honda/Acura motors I have tuned seem to make the most power. Granted these are street cars, and others here may have different experiences. Either way, my next mod would be to get the fuel right. Then worry about more mods...
Jason
Old Dec 8, 2001 | 03:29 PM
sgT's Avatar
sgT
how about a better exhaust?
Old Dec 8, 2001 | 03:35 PM
TypeR76's Avatar
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (sgT)
like 2.5" custom exhaust?
Old Dec 8, 2001 | 11:07 PM
t's Avatar
t
Am I the only one that thinks the torque is a little weak for those cams??
Old Dec 8, 2001 | 11:47 PM
GokuSSJ4's Avatar
how about some nice headwork and also dyno tunning the car to gain the best out of the cams !
Old Dec 10, 2001 | 02:23 PM
Black R's Avatar
25 Year Member
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (t)
Stock compression!
William!
Old Dec 10, 2001 | 02:28 PM
Cosworth's Avatar
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (Black R)
Will - very good numbers! BTW, want to get a group rate for test-n-tune? Trey (ID = Trey) wants to test-n-tune next week. If you're interested let us know (cosworth_396@yahoo.com) . Also, maybe Ken and Shane might be interested as well.
Old Dec 10, 2001 | 02:42 PM
Black R's Avatar
25 Year Member
Default Re: made 192.6 hp and 123.2 tq. second trip but with a Field controller (Cosworth)
Yup, and don't forget there's more power in his car with stock b-pipe!
F the peak numbers! Remember, he's experiencing gains over his last trip with just a little tuning. He'll be back and has more to gain with some fuel adjustments...
Popular consensus is to add fuel up top and you'll gain power if already running lean.
Just think: ~200whp on stock compression! With ac, ps, etc...
again William! :
Old Dec 10, 2001 | 03:03 PM
Ex-ITR5874's Avatar
I have a similar setup, not installed yet, but I would go for a stronger fuel pump and a power fc. I don`t know the fields. Is it able to raise the redline ?
How much is you hp at crank ? I guess it`s more than 210hp so it`s recommended to go for 2,5`` exhaust. Would give you a better harmony between airflow (speed) and the volume that is moved through the exhaust..
Just my two cents..
JDMOrangeFever
Jun 23, 2005 01:18 AM
turkdog
Dec 1, 2003 07:30 PM
xXBlackXGSRXx
Sep 27, 2003 02:03 AM
nullbert
Apr 30, 2002 09:51 AM
MPH
Jan 31, 2002 03:57 PM
