SKUNK2 STAGE 2 CAMS
Old Sep 12, 2004 | 05:56 PM
DC2 9K VTEC's Avatar
Default SKUNK2 STAGE 2 CAMS
I'M RUNNING SKUNK2 STAGE2 CAMS, BUT MY VTEC STUTTERS AROUND 4-5K RPM
I TRIED A SKUNK2 CHIP, IT HELPED A LITTLE, BUT STILL STUTTERS. AFTER 5K RPM, VTEC PULLS HARDER THO.
Old Sep 12, 2004 | 06:20 PM
Darkane's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (DC2 9K VTEC)
I think those cams need a Vtec engagment of around 5.5-6k for the torque curve not to drop. The shuttering or whatever is probably due to vtec set stock and no tunning.. Dyno tune and you'll find they will perform better.
Old Sep 12, 2004 | 09:04 PM
RynoDyno312's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (Darkane)
yeah you're gonna need to raise the vtec engagement point. night as well get a vafc so you can do a little tuning while you're at it.
Old Sep 13, 2004 | 03:46 AM
Default Re: SKUNK2 STAGE 2 CAMS (RynoDyno312)
did u guys learn this from experience? or heard from someone? with a skunk2 valvetrain, how high can i rev my engine before it gets too dangerous? thanks
Old Sep 14, 2004 | 07:56 PM
Bigjussin's Avatar
this helped me a lot as well.....what do u guys have your valves set at...i went to inline four and used the stock settings of 7 and 8 like they said, but my valves are way noisy
Old Sep 14, 2004 | 09:01 PM
mr.beeks's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (Bigjussin)
really getting cams and no tuning done with it
it misses the point
dont forget that cams
work between a range that
at some point it makes power after a certain point it just stops making it.
so a chip really doesnt work
get a piggyback sistem ex
vafc
or
hondata
and dyno that baby you will find the hp you are missing
Old Sep 14, 2004 | 09:17 PM
GrayT's Avatar
What do you mean by stutters? It engages VTEC but doesn't start to actually pull until 5k?
Old Sep 17, 2004 | 08:09 AM
oldskool teggy's Avatar
Default Re: (GrayT)
try using a honda oil filter. i had a fram on there once and it caused my car to stutter engagin vtec.. somehtign to do with oil pressure
Old Sep 17, 2004 | 08:23 AM
lapok25's Avatar
Dyno tune it. You need to raise the vtec point. This usually happen if you put a performance cams.
Old Sep 17, 2004 | 08:41 AM
lke2drvgsr's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (lapok25)
stage2 cams are made for higher compression motors, i.e. about 12.0:1. stage1's are better for a stock compression motor... your powerband will have gone to **** and you MAY have gained MAYBE a few horses up top, but lost a shitload below. also, check your oil level too...
Old Sep 20, 2004 | 05:55 PM
Bigjussin's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (lke2drvgsr)
what does everyone have their valves set at?
Old Sep 20, 2004 | 06:39 PM
HONDA_TYPE_R's Avatar
You may not have enough oil pressure when your VTEC engages that is probably what is causing the stutter. The pressure is there, but it's not quite enough. If you had an ITR oil pump, you may get a little more pressure (not sure what motor or other mods you have though).
I would highly suggest that you get your setup tuned. Usually chips will cause your motor to run rich. Without tuning, the chips benefits will not be seen. Dyno tuning will also tell you where your motor/cams are running out of power. You may want to consider some bottom end upgrades if you are going to go much over the stock rev limit (again not sure of what mods you have).
What are you guys referring to when you say what your valves are set at? Timing? Just trying to get a grip on this thread that's all.
Old Sep 20, 2004 | 07:24 PM
91integraLSVTEC's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (HONDA_TYPE_R)
running stock header? if so get a dcsport or similar header. had same problem, stock header choked the engine causing it to studder.. had skunk stage 2 cams with built head on a stock block b16. dynoed at 163whp. lost low end? 111 torque throughout the whole powerband. i didnt lose anything but gain **** load of power with those cams.. went through 2 motors with these cams and i'll soon throw them in my stock b18cr.
Old Sep 20, 2004 | 07:55 PM
JFG Kevin's Avatar
Default Re: SKUNK2 STAGE 2 CAMS (91integraLSVTEC)
what kind of valves are you guys using with these s2 cams? I'm thinking of putting in my stage 2 with s2 valvetrain too, also with a s2 chipped, i been warn that it'll lag between 4-5 but when dual vtec kicks it'll make up alot of it. I'm planning to go 9 grand with stock bottom.
austinwasthere
Jun 17, 2014 11:58 AM
Gong Show
29
Sep 26, 2007 05:51 PM
greatwhiteshark
10
Mar 28, 2006 02:53 PM
KamikazeRacinz
Sep 9, 2002 06:29 AM
matteg02
Apr 4, 2002 06:58 PM
