having slugish braking...time for new brake pads?????
Old Sep 12, 2004 | 03:33 PM
hondaracin24's Avatar
Default having slugish braking...time for new brake pads?????
My braking on my accord is starting to get pretty bad. When brake fluid was added at my last oil change they worked great and now I basically have to press brake all the way in to halt to a stop. I dont think filling with more brake fluid would solve the problem. Also at high speeds 60 mph + the car shakes. So im guessing I should get the rotors turned over as well. Do you think its just a better idea to buy some new brembo blank rotors and pads? Not quite sure what to do here....
Old Sep 12, 2004 | 04:55 PM
FatJoe's Avatar
Default Re: having slugish braking...time for new brake pads????? (hondaracin24)
if the car shakes without pressing on the breaks, more than likely you will need to rebalance ur tires... now if it shakes while ur pressing the brakes... def need to return the rotors... maybe your master cylinder is goin out for ur breaks, have it checked out, or check it out urself. when they go bad, you can be pressing the brake, and itll keep going down like ur pushing fluid through something. you can easily check the brakes too...take off the wheels and look at em, not hard at all.
Old Sep 12, 2004 | 06:49 PM
Schmitey's Avatar
Default Re: having slugish braking...time for new brake pads????? (FatJoe)
yeah check the master cylinder...abs still work?
Old Sep 13, 2004 | 08:51 AM
abs is workin just fine.....
Old Sep 13, 2004 | 08:46 PM
hondaacuratech's Avatar
this is how you check your master cylinder. start your engine and let it idle then hold the brake paddle down if it goes down all the way. it is bad otherwise, air inside the brake system.
Old Sep 14, 2004 | 10:32 AM
Default Re: (hondaacuratech)
how much would it cost to replace a part like this? I believe that is the problem......
phoenixitc's Avatar
Master brake cylinder very very popular replacement item Pedal going to floor is sure sign of this.
Old Sep 14, 2004 | 03:16 PM
Default Re: (phoenixitc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenixitc &raquo;</TD></TR><TR><TD CLASS="quote">Master brake cylinder very very popular replacement item Pedal going to floor is sure sign of this.</TD></TR></TABLE>
Is it something that my local dealership would carry or would I have to order the part online?
Old Sep 15, 2004 | 02:53 AM
phoenixitc's Avatar
Yes and if you do it yourself, http://www.tasauto.com sells the hardware. Don't forget about bleeding the brakes. Best to have a brake shop or dealership do it.
Old Sep 15, 2004 | 03:18 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenixitc &raquo;</TD></TR><TR><TD CLASS="quote"> Best to have a brake shop or dealership do it.</TD></TR></TABLE>
Why?? If you have about 2 hours and a couple metric wrenches you can do it yourself for about 1/2 the price. (for the master cylinder)
IS your pedal going to the floor?
If your brakes are just shaking upon braking then it sounds like you need to get your rotors honed and pads replaced.
Make sure you have a chiltons/helms/haynes manual close by .
Old Sep 15, 2004 | 08:44 AM
luckydog's Avatar
It would also be a good idea to have your fluid changed. Brake fluid absorbs water. Water is bad.
Old Sep 15, 2004 | 10:18 AM
phoenixitc's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure you have a chiltons/helms/haynes manual close by .</TD></TR></TABLE>
Several reasons... first, it didn't appear or sound like this person would want to do it, based on the level of questioning, second, not everybody wants to or cares to do it themselves.
Old Sep 15, 2004 | 04:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">IS your pedal going to the floor?
Its not going to the floor but enough where I have to push it more than I should have to....
Old Sep 15, 2004 | 05:33 PM
The_Todd's Avatar
Farts in the shower
Default Re: (hondaracin24)
Before you go and replace parts you may not need to I would do the following:
Get rotors honed down
Check wear on pads and replace
bleed the system
IF the problem of the pedal going to the floor persists then it is your master cylinder.
Are you planning on doing your own brake job or paying someone? Do you have 4 wheel disc or front disc rear drum?
Old Sep 16, 2004 | 02:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Are you planning on doing your own brake job or paying someone? Do you have 4 wheel disc or front disc rear drum?</TD></TR></TABLE>
I plan on paying someone for that I dont have the skills nor do I want to mess anything up. Its a front disc and rear drum brake setup....
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
drewski101
10
Aug 17, 2008 06:21 AM
slow91crx
May 30, 2006 07:55 AM
CXHatchback
21
Mar 20, 2003 07:13 AM
d0nkeyxPunch
Oct 26, 2001 09:28 AM
