the age old question.......
Old Sep 12, 2004 | 03:27 PM
Btothe3rdDegree's Avatar
Default the age old question.......
what the f*ck is wrong with my car!!! ok 92 civic 4dr dx d16z6 yada yada yada. i start it and it turns over it just wont fire, so i checked spark. all four got spark, checked fuel at the fuel filter, got fuel. checked fuel at the rail, got fuel. i dont know how to check it at the injectors so i didnt. i have 450 dsms and a resistor box. which i think is the problem. i wired it the ghetto way, cut the yellow and black wires about a foot from the rail , wired the red wires on the injector side and the black wire on the harness side. which should be right. is there anyway to check if injectors work? i pulled them from the intake but there is no way i can hold 43 psi worth of fuel. i thought i could pull the mani off and see if they release fuel, but i cant do that because i will leak coolant all over the place. anyone know what it could be?
thanks guys
Old Sep 12, 2004 | 03:39 PM
xenocron's Avatar
Default Re: the age old question....... (Btothe3rdDegree)
pull the plugs in each of the cylinders and see if they are wet or that cylinder smells like fuel
besides, fuel and spark...you also need compression...check your compression
Old Sep 12, 2004 | 03:45 PM
MooreBoost's Avatar
Default Re: the age old question....... (xenocron)
You need a node light. See if you can borrow one from a local mechanic you know. Place it against the injector while having someone turn over the car and it should light up if it fires. If it doesnt, then that injector is your problem.
Old Sep 12, 2004 | 04:30 PM
Default Re: the age old question....... (tegunderpressure)
yeah we smelled em, nothin. my neighbor said he has a device that you put between the injector and the connector and it tells you if the injector is getting a signal. cant i just use a volt meter and see if the injectors are getting a signal?
Old Sep 12, 2004 | 04:32 PM
MooreBoost's Avatar
Your neighbor is talking about a node light. Just borrow it.
Old Sep 13, 2004 | 04:55 PM
does it sound like my injectors are wired correctly?
Old Sep 14, 2004 | 02:11 PM
need help she still wont turn over
i checked the resistor box all the wiring is correct
when i start her she will turn, but she wont turn over
i get spark and fule to the rail but it seems like the injectors just arent firing
arggggg i am sooo close
Old Sep 14, 2004 | 03:34 PM
what if i took out the resistor and put the stock injectors and tried to fire it up? i am running uberdata set at 450 injectors will it cause any conflicts
Old Sep 14, 2004 | 04:12 PM
Johnyquest's Avatar
just pull out your entire fuel rail with the injectors still in it and crank the car real quick, i did it and my injectors didn't fly out... they just squirted. I'm pretty sure fuel is your problem, though. Re-do your wiring.
Matt
Old Sep 15, 2004 | 01:52 PM
Default Re: the age old question....... (Johnyquest)
alright i first checked for cel's nothing
i then pulled my chipped p28 and put in the stock p06, didnt make a difference
then i pulled out the resistor box rewired everything and put in the stock injectors, still same result it turns over but it will not fire.
couple of questions
-how many grounding points are there? i have three, one on the valve cover, one by the tranny, and one on the driver side of the intake manifold
- the ground from the intake manifold i didnt have so i just made one and ground it with the one from the valve cover, will this cause problems, also i dont think the gauge is very thick
-i have some oil leaking from my oil filter, this has never happened before, i did switch to synthetic if that makes a difference
-can i put some fuel in the spark plug holes and try to turn it over?
need help guys i need to get her running
Old Sep 15, 2004 | 02:06 PM
Bailhatch's Avatar
ok, getting fuel, getting spark, now check compression (you would need a compression gauge for this) and cam to crank alingment by lining up the TDC marks on the crank and the cam sprockets. If the cam timing is way off the distributer would be off as well so spark could be early or late. The cam timing also affects compression #s too.
Old Sep 15, 2004 | 02:46 PM
Default Re: the age old question....... (Bailhatch)
see thats the thing i am not getting fuel, i am getting it at the filter and at the fuel rail but the injectors arent firing, i tried the stock ones and they dont fire either, and yes i did i compression test all numbers within 5
Old Sep 15, 2004 | 05:08 PM
well i checked everything and i am not getting voltage to the injector connectors. anyone know what might be wrong? haynes says it might be a worn harness (doubt it) or the main relay anyone know what might be wrong and how i can check?
also what is the resistance of a 450 dsm?
Old Sep 17, 2004 | 03:54 AM
ttt
ogorek
Honda Civic (2006 - 2015)
Nov 15, 2015 01:56 PM
uses0ap
May 1, 2009 07:30 AM
CRXWOLSKI
17
Jan 10, 2008 03:11 PM
4doorcivic16
Feb 27, 2007 07:18 PM
kustomize89
10
Feb 6, 2004 03:38 PM
