cam gear setting on ls/vtec...did search
Old Sep 12, 2004 | 02:32 PM
87b16crx's Avatar
Default cam gear setting on ls/vtec...did search
i am looking for what everyone else is running for cam gear settign on basically any NA motor. i have an ls/vtec with the mods in my signiture (the 91 hatch). i want to start tweaking on the cam gears but the closest dyno is over 350 miles away and i know it would be the easiest way and more efficent way to tune it but i have no time to make the trip. i work damn near 7 days a week and when i have a day off, all i want to do is sleep. i have read people advancing the intake +2-4 and retarding the exaust -0-2. the track i race at is at an elevation of a little over 5500 FT and i am at a 15.23 consistant. 15.07 is my best i have run with this motor. but if ay of you have any ideas, that would be helpful. thanks.
Old Sep 12, 2004 | 05:49 PM
LSVTEC 91 Civic's Avatar
Banned
You don't want to advance it too far, with every degree you advance on the cam you advance total ignition timing another 2 degrees. If you do make sure you have a timing light standing by ready to readjust ignition timing.
What Pistons / Cams are you running? If its stock, you'll probably be fine going no more than 4 degrees on the intake side.
Old Sep 13, 2004 | 05:19 AM
87b16crx's Avatar
i am running PR3 b16 pistons and GSR cams. nothing wild.
Old Sep 25, 2004 | 02:48 PM
W0oT's Avatar
Banned
Default Re: cam gear setting on ls/vtec...did search (87b16crx)
i got the same setup... so i figured advance the intake 2-3 and exhaust -1 -2
eg6BT
Oct 2, 2006 07:59 PM
donnjuan2point2
Apr 20, 2004 11:20 AM
[HrZn]4life
May 13, 2003 03:17 PM
White98LS
Mar 24, 2002 05:41 PM
