JG IM and Idle question..
Okay,
I've got a built gsr w/ a JG IM.. before when my motor was still stock and w/ teh stock IM, my idle was normal , about 700-900 rpm.. now w/ this JG, my Idle stays around 1K rpm and never drops to stock..
I'm just tryin to pinpoint why I"m having this problem.. i've checked all gaskets, and vac leaks... all are good.. i've even messed w/ the idle screw, cleaned the iacv, and still no sucess.. what else is there to check?
Tps
thats exactly what was happening to me but my idle was bouncing a bit to.
Check the tps and was getting a .76V idle, tried to adjust but it would go low enough (.45-.50V) So I grabbed one from a junkyard for 5 bucks and the problem went away
Check your t/b gasket as well
Civic Racer X 7
Jul 23, 2003 07:19 AM
