Hood Clearance Problems
Old Sep 12, 2004 | 02:04 PM
rhetorical's Avatar
Default Hood Clearance Problems
I've got an '88 CRX with a b18c5 and my new cf hood isn't quite fitting over the engine...., does anyone know of a hood that will fit? perhaps a massive bulge in it, or something of the sort, I really don't want to be cutting up my CF hood... I might just go back to the basically skinned hood I had on before it that has a couple blemishes
Old Sep 12, 2004 | 02:06 PM
Home Skillet's Avatar
Default Re: Hood Clearance Problems (rhetorical)
What motor mounts did you use? The last time I did a B18C5 swap in a CRX we used Hasport mounts and still had to cut the hood webbing.
Old Sep 12, 2004 | 02:16 PM
manson's Avatar
Default Re: Hood Clearance Problems (Home Skillet)
Fiber Images makes a USDM SIR style hood that will clear any b series with any mounts.
VIS might make one too, but i would rather buy FI than VIS.
rather cut the webbing its cheaper and can be done nice so it doesn't look horrible every time you open the hood. cutting wheel and some power....
Old Sep 12, 2004 | 02:28 PM
Rywire's Avatar
Default Re: Hood Clearance Problems (manson)
Quoted from my site.
There are a few options here. You can get a sir front end conversion, sir style hood for usdm front ends, or just cut your stock one. Thats what I did, I cut 2 "ribs" out of the hood on the driver side, above the valve cover.
Ryan
Old Sep 12, 2004 | 02:37 PM
87b16crx's Avatar
ya if your using the USDM hood, it will rub in a few spots. but if you get the jdm "style" with the cowl bulging up rather than dipping down, it should clear. i have a 91 with an ls/vtec and VIS SIR style hood and it clears with no problems.
Old Sep 12, 2004 | 02:42 PM
LoneStarCRX's Avatar
Default Re: Hood Clearance Problems (droppedcrxsi)
Would a ZC hood work? I have a couple to sell and since you are in Austin, I will be down that way October 9-10 for the meet in San Antonio. I could bring them down. They are pretty banged up because of the idiots who ship them from Japan. I'd make you a great deal on one. You would need to get the dings and stuff out of it. I am having a shop do mine with the other front end repairs I need. You could see the results if you make the meet.
Old Sep 13, 2004 | 07:22 AM
Default Re: Hood Clearance Problems (dewarcr)
I don't think a ZC hood would work for the B18C5.
Old Sep 13, 2004 | 10:17 AM
Rywire's Avatar
It will need a lil trimming still.
Ryan
Old Sep 13, 2004 | 11:11 AM
CRX T-Si's Avatar
Why do you just put a few washers on the back of the hood hinge to raise that sucker up a little so it does clear??
It helps the engine bay cool better also, that is a 2 for one deal.
Old Sep 13, 2004 | 12:11 PM
dingusjt's Avatar
Default Re: Hood Clearance Problems (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Why do you just put a few washers on the back of the hood hinge to raise that sucker up a little so it does clear??
It helps the engine bay cool better also, that is a 2 for one deal.</TD></TR></TABLE>
exactly what I did on my b18c swap...might was well try before you start cutting, hell it only costs about 50 cents and a .5 inch lift wont even be noticeable.
Old Sep 13, 2004 | 12:14 PM
rhetorical's Avatar
It allready is lifted for some reason, probably about .25 inches, but I'll go try putting some washers on and if that doesn't work it's cut time. by the way I'm currently using the VIS CF hood with the bulge in it
Old Sep 13, 2004 | 12:28 PM
CRX T-Si's Avatar
Default Re: (rhetorical)
Something doesn't fit right here.
If you have the VIS hood with the SiR buldge and it still rub??
Something ain't right man..........
Old Sep 13, 2004 | 06:22 PM
Rywire's Avatar
Default Re: (CRX T-Si)
I didnt mention the washer alternative because my friend with a r engine did this, and to me it looked tacky. But function over fashion.
Ryan
Old Sep 14, 2004 | 12:39 AM
sinfultrends's Avatar
Default Re: (droppedcrxsi)
washer raised hood is used very often in japan to vent heat out of the engine bay.. its useful in cars like 240sx and RX7.. but i dont know if heat is a big issue in honda engine bays.. my crx has the smallest friggin radiator
Old Sep 14, 2004 | 04:55 AM
CRX T-Si's Avatar
Default Re: (sinfultrends)
When your EF is turbo, you need to vent as much hot air as possible.
Never knew that washer thing is JDM.......funny ****.
Old Sep 14, 2004 | 06:06 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">Fiber Images makes a USDM SIR style hood that will clear any b series with any mounts.
rather cut the webbing its cheaper and can be done nice so it doesn't look horrible every time you open the hood. cutting wheel and some power.... </TD></TR></TABLE>
Yeah, I've got the fiber Images USDM SiR hood, for sale. Cleared my B16 like a champ.
Old Sep 14, 2004 | 07:09 PM
rhetorical's Avatar
Default Re: Hood Clearance Problems (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote"> Cleared my B16 like a champ. </TD></TR></TABLE>
Pretty sure the B18C5 sits higher up than the b16
Old Sep 14, 2004 | 08:27 PM
Kyoji's Avatar
Never knew that washer thing is JDM.......funny ****.</TD></TR></TABLE>
It isn't.
Old Sep 14, 2004 | 09:32 PM
Trevor's Avatar
Default Re: (Kyoji)
I have the Fiber Images JDM style hood. It clears my B16 With Hasport mounts.
Modified by Trevor at 5:36 PM 9/16/2004
freedm
18
Jan 14, 2009 07:08 PM
djphonics
Sep 23, 2006 12:02 AM
pvt_awol
Nov 4, 2004 02:11 PM
apexinghonda
May 24, 2004 01:28 PM
GreenR
Aug 21, 2002 04:00 AM
