speedometer bounces / fluctuates / erratic
Old Sep 12, 2004 | 01:35 PM
IVI's Avatar
IVI
Default speedometer bounces / fluctuates / erratic
when im driving highway speeds sometimes the speedometer bounces around to 140 - 150 - passed the numbers - 0 - 30, all around.
cant use my cruise control because it keeps giving gas and not gassing.
any ideas?
1996 integra obd1 swap
Old Sep 12, 2004 | 04:10 PM
IVI's Avatar
IVI
Default Re: speedometer bounces / fluctuates / erratic (IVI)
bumper
Old Sep 12, 2004 | 04:54 PM
sabotage7's Avatar
sounds like some sorta ecu problem....sometimes the ecu will do crazy stuff like that when its going bad....but if thats the case, its usually more than one guage that acts up.... is that the only guage thats acting weird? since its a swap, id hafta guess that maybe you just have a loose wire or something.
Old Sep 12, 2004 | 04:58 PM
IVI's Avatar
IVI
Default Re: speedometer bounces / fluctuates / erratic (sabotage7)
it usually does it under heavy acceleration.
or above 90mph.
normal driving usually wont do a thing.
Old Sep 12, 2004 | 06:02 PM
1stGENGSR's Avatar
Sounds like your speedometer cable, your speedometer is mechanical......It is run by the VSS (Vehicle Speed Sensor) which sits in the top of the transmission, the ECU has nothing to do with it (not in an Integra anyway)! If not your cable check your VSS, it has a coax looking cable that goes into it on the top of your tranny near the firewall........It's more than likely one or the other..................
Old Sep 12, 2004 | 07:54 PM
IVI's Avatar
IVI
Default Re: speedometer bounces / fluctuates / erratic (1stGENGSR)
its a 1996 if any help?
are you sure it has a cable? i took the cluster out its all electronical
where is the cable located?
Old Sep 12, 2004 | 08:05 PM
rgbpmp's Avatar
Try cleaning your speed sensor. Ive heard of problems like yours, and ends up being speed sensor. Its located on the transmission.
Old Sep 12, 2004 | 08:20 PM
IVI's Avatar
IVI
Default Re: speedometer bounces / fluctuates / erratic (rgbpmp)
pics or detailed information would be helpful.
Old Sep 12, 2004 | 08:30 PM
rgbpmp's Avatar
Looks like its by the starter.
Old Sep 12, 2004 | 09:10 PM
s2kkid's Avatar
hey IVI,
I have the same problem.. Itll work fine sometimes, and then go away...
Im pretty sure its the speedsensor
Old Sep 12, 2004 | 09:13 PM
IVI's Avatar
IVI
thanks guys for the replies and the pictures.
i will try to clean the vss and let everyone know in a couple of days the outcome.
Old Sep 13, 2004 | 03:43 AM
wsiracerz's Avatar
this happened to a couple of my friends cars, it was the speed sensor every time, not saying it is but theres a good chance
dirtracer
Feb 9, 2005 06:36 AM
bumthology
Sep 29, 2004 02:26 PM
crxforum
Jun 13, 2004 11:24 AM
Spunkster
Jan 10, 2004 05:22 PM
solman74
Sep 10, 2003 09:59 PM
