can i turn over a dry motor manually????
Old Sep 12, 2004 | 12:56 PM
blackeg's Avatar
Default can i turn over a dry motor manually????
i got an ls swap at my house right now. timing belt is a little loose and **** like that. there is no oil/coolant in the motor, and the motor is out of the car. if i want to manually turn it over, can i do that with the oil not full? is there a proper proceedure to do this(besides fill it with oil?) i want to get this situated, cause when the motor goes in the car, i cant get my torque wrench anywhere down on the camgear side.
Old Sep 12, 2004 | 01:17 PM
Revolver's Avatar
Default Re: can i turn over a dry motor manually???? (blackeg)
Can't you just use a breaker bar or torque wrench at the crank to rotate?
Old Sep 12, 2004 | 01:20 PM
garados's Avatar
you'll be fine rotating it a few times dry. Don't forget to take the spark plugs out
Old Sep 12, 2004 | 03:19 PM
blackeg's Avatar
Default Re: can i turn over a dry motor manually???? (garados)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados &raquo;</TD></TR><TR><TD CLASS="quote">you'll be fine rotating it a few times dry. Don't forget to take the spark plugs out </TD></TR></TABLE>
oh ****! hahaha. i put a socket on the crankpulley, and wedged it so that the motor wouldnt rotate. overall it might have moved 1/4 crank turn, so like no where near a full cam rotation. that was for me taking off the clutch and flywheel. ill def take the spark plugs out when i tighten the timing belt again.
EF8DayDreamer
Jan 18, 2012 10:12 PM
Global688
Nov 27, 2007 05:27 AM
Peruviann83
Mar 15, 2007 05:50 PM
gsp ej1-em1
May 18, 2006 06:02 PM
