What size turbo? buiilt ls
Old Sep 12, 2004 | 11:31 AM
airwalk07143's Avatar
Default What size turbo? buiilt ls
i got a fully built ls w/ benson sleeves cable gsr tranny but i dont know waht size turbo i want to use i what looking at a gt35 or possible sc61. im looking to get about 500-550 whp. will be using hondata. what trim am i goin to want?
Old Sep 12, 2004 | 01:00 PM
95GSRTT
Guest
Posts: n/a
Default Re: What size turbo? buiilt ls (airwalk07143)
go with the t25 its beast!
Old Sep 12, 2004 | 02:18 PM
Tchleung's Avatar
Default Re: What size turbo? buiilt ls (95GSRTT)
Um what? Are you talknig about the DSM T25?
Old Sep 12, 2004 | 02:29 PM
95GSRTT
Guest
Posts: n/a
Default Re: What size turbo? buiilt ls (Tchleung)
i was being sarcastic, and yes i was...
Old Sep 12, 2004 | 02:55 PM
Tchleung's Avatar
Okay cause I wasn't sure weather to whip out blah blah blah or not hehe.
Old Sep 13, 2004 | 06:35 PM
any ideas
Old Sep 13, 2004 | 06:40 PM
b16sedan's Avatar
Drove a GT35R car, the boost response was fantastic, although I am quite happy with my SC61S.
Old Sep 14, 2004 | 04:47 AM
Default Re: What size turbo? buiilt ls (b16coupe)
how much horse were u making and im assuming u have a b16?
Old Sep 14, 2004 | 07:24 AM
Honda Hick's Avatar
Good luck making 550 horsepower with an LS. I think your goals are a bit unrealistic. What kind of headwork do you have done? What compression are you running? These types of things will help in picking a turbo, but I really don't think 500 is going to be possible. You're going to need something bigger than a SC61 too.
Old Sep 14, 2004 | 07:42 AM
95GSRTT
Guest
Posts: n/a
Default Re: What size turbo? buiilt ls (Honda Hick)
why the hell would 550 whp be unrealistic b/c its an LS? Please explain that ideal to me....
Old Sep 14, 2004 | 07:43 AM
silverb18's Avatar
If you have a fully built LS motor, why don't you put a fully built Vtec Head on top of that?
Old Sep 14, 2004 | 08:38 AM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">why the hell would 550 whp be unrealistic b/c its an LS? Please explain that ideal to me....</TD></TR></TABLE>
Show me some dyno graphs of 550 HP LS motors then. You would need to do a ton of work to them to get that type of power (block girdle, massive headwork, etc.). Unrealistic on anything other than a drag car at least.
Old Sep 14, 2004 | 08:49 AM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">
Show me some dyno graphs of 550 HP LS motors then. You would need to do a ton of work to them to get that type of power (block girdle, massive headwork, etc.). Unrealistic on anything other than a drag car at least.</TD></TR></TABLE>
Block girdle, what the hell are you talking about? You arn't going to make 550 WHP on stock sleeves and a block girdle. I'm running a sleeved motor, fully ported alaniz head, and aftermarket cams in my SIR, and it used to be my daily driver, how is that unrealistic? What you're saying doesn't make any sense.
Old Sep 14, 2004 | 09:34 AM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Block girdle, what the hell are you talking about? You arn't going to make 550 WHP on stock sleeves and a block girdle. I'm running a sleeved motor, fully ported alaniz head, and aftermarket cams in my SIR, and it used to be my daily driver, how is that unrealistic? What you're saying doesn't make any sense.</TD></TR></TABLE>
No kidding, a block girdle between the main caps for the crank because a LS doesn't have one stock. You're going to have to rev the **** ouf a LS if he wants to make that much power so he'd need a block girdle of some type. He already said he had sleeves done, but didn't have any specifics on anything else.
Was the motor in your "SIR" a LS motor pushing 550 horsepower as a daily driver?
Old Sep 14, 2004 | 09:43 AM
b16sedan's Avatar
When you said girdle I was reading quickly and mistook it for block guard.
An LS motor will still have roughtly the same power potential as an LS/VTEC or a GSR, it's just going to take more boost to get there, so theres's no reason why he shouldn't be able to make 550 WHP out of a streetable LS motor.
And no, the motor in my REAL SIR (I'm from Canada) was not pushing 550 WHP as a daily driver, but it was making over 440. It's a turn of the boost **** and some race gas away from 550+ WHP, just like a lot of peoples street cars on here.
Old Sep 14, 2004 | 10:48 AM
DSF's Avatar
DSF
Show me some dyno graphs of 550 HP LS motors then. </TD></TR></TABLE>
Taken from http://www.importreview.com/d_turbo.html.
Old Sep 14, 2004 | 11:23 AM
Armaan's Avatar
Default Re: What size turbo? buiilt ls (DSF)
Nice. Now if they could post the specs, that would be great.
lsturbojay4
Oct 15, 2008 08:17 AM
ggfg2
Jul 22, 2008 04:01 PM
lllIntegralll
May 21, 2006 06:20 PM
B16A3Civic*Eg
May 4, 2006 06:17 PM
mr.roboto
Aug 27, 2005 12:16 PM
