WTT: B series swap with high compression LS motor & GSR trans for SOHC VTEC
Decided to go a different route with my car, so I would like to get rid of my re-built LS swap for a d16z6 longblock and tanny + cash. My swap incudes...
Before engine was built, it was freshly honed, and every used part (block, crank, rods etc) were cleaned in the hot tank.
Re-built B18a1 engine rebuild includes:
Brand new ACL bearings, rod and crank
Brand new B16 pistons
Brand new OEM piston rings
Brand new OEM valve cover gasket, oil pan gasket, head gasket and other misc gaskets
B16 oil pump
B16 oil pan
Other swap parts include
odb2 LS distributor re-wired to odb1
all nessisary hoses/wiring
both axles, one new from carquest
half shaft
GSR shift linkage and shifter
96 GSR transmission with 90k
all mounts
JDM b16 clutch, pressure plate and flywheel
nology spark plug wires w/new platnum plugs
LS header w/new exhaust gasket
All other nessisary parts for this engine to run, this a complete swap
been running the motor in my car temporarily, 250.4 miles on it right now
I would like to trade for a d16z6 longblock and transmission with near 100k or less, ECU, and passenger side axle. + cash (pm me offers), or motor + black 15" rota slipstreams and cash
located in salem oregon will not ship, must pick up and deliver
Modified by Simple at 11:02 AM 9/26/2004
B16 oil pump
B16 oil pan
half shaft
all mounts
this is a bad *** deal too bad your not in socal, i wouldve addded top hot dolla's on a trade like this
free biZZump
free biZZump
i have a sohc motor for you. its vtec. haha, vtec-e. hahaha. yeah, i wish i had a better motor. the vtec-e is good on gas and evrything, but slow compaired to my last car.
put more OEM parts on the motor today,
new OEM TB gasket
new OEM plug wires
new OEM intake manifold gasket
d16z6's only please
new OEM TB gasket
new OEM plug wires
d16z6's only please
I would like to buy your LS, I need one realy badly. I have a D15 out of a CRX, and $1350 in cash. I dont know if that helps but IM me if your interested.
unless you plan to drive yer *** all the way to oregon it doesnt help out much.. haha... let me know
I dont know if I'd make it hahahaha. I wish shipping wasn't so ******* expensive, ohh well the search continues.
Simple
Jan 1, 2005 11:56 PM
Simple
Oct 21, 2004 01:58 PM
