serious coolent problems in a Zero mile b18c1
Old Sep 12, 2004 | 07:35 AM
JBBNJ609's Avatar
Default serious coolent problems in a Zero mile b18c1
i have an engine thats at the tuner right now , we start iut up and water is in the top tube of the rad but the bleeder valve on the head is dry and the lower (return) rad hose is 100% DRY , we took out the thermostat at is was dry with NO water behind it . . what could be the problem ??
its running and gets up to 200 temp before we shut it off . . .
HELP i need this fixed so i can get my car up and running . . .
the water pump is not leaking and looks fine( spinning fine on the timing belt)
Old Sep 12, 2004 | 01:20 PM
JBBNJ609's Avatar
Default Re: serious coolent problems in a Zero mile b18c1 (jason bouchard)
bump HELP
Old Sep 12, 2004 | 03:35 PM
k-roy's Avatar
Umm, did you put enough coolant in it?
It should be around a gallon and a half for the total system.
Old Sep 12, 2004 | 04:38 PM
JBBNJ609's Avatar
Default Re: serious coolent problems in a Zero mile b18c1 (k-roy)
yea haha , even if i didnt put the reg amount water would come out of the return tube if things were working ok
Old Sep 12, 2004 | 04:45 PM
Tweakmeister's Avatar
head gasket?
water pump?
probably water pump
Old Sep 12, 2004 | 04:59 PM
sPaRk'iT's Avatar
Double check your water pump.
Old Sep 12, 2004 | 05:20 PM
JBBNJ609's Avatar
Default Re: serious coolent problems in a Zero mile b18c1 (sPaRk'iT)
how?? ( do i double check it)
i hear the only way it breaks is if it starts "weeping" leaking . . its powered by the timing belt so how could it break ?
Old Sep 12, 2004 | 05:35 PM
MAV3RiCK478's Avatar
edited for a really dumb answer, sorry
Old Sep 12, 2004 | 06:36 PM
was it resleeved? check your oil pan...(for water)
if not keep filling it until water starts coming out? I mean come on, there's only so many places or things it could be.
Old Sep 12, 2004 | 08:20 PM
esponet's Avatar
did you guys bother to look on theground to see if its spilling from somewhere?
Old Sep 16, 2004 | 01:20 PM
JBBNJ609's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">did you guys bother to look on theground to see if its spilling from somewhere?</TD></TR></TABLE>
hahah yea, and there was none
i found out that my rad. needed to be higher and i had a **** load of air in there (fixed)
dleccord
Jan 11, 2010 06:59 PM
niceprelude
Feb 15, 2009 10:20 PM
snowblind7x
Sep 3, 2008 01:31 PM
wedtm
Mar 26, 2008 07:59 PM
dclub01
Apr 5, 2003 01:50 PM
