distributors ?!?!?!?!?!?!?!?!?!? please help
(91crxsi) will a zc distributor work on a d16a6 or a d15b n/v or can i use a distributor off of a newer civic. i have a 92+civic d15b7 distributor but it dose not have the same plug can it be changed. i have the jdm d15b n/v no number strate (d15b) the repair shop changed out the motor and used the distributor off of the d16a6 on it. but also a d15b7 can be run in its place but has a diffrent style of distributor but can run ether or. so if that the case can it be used with mods done to it????
from what i have always heard you can not use the ZC dizzy on the D16a6. as for all the other combos i don't know.
But if you need a D16a6 dizzy email me at mwelshiemer@aol.com i have one off my blown engine..and i am in need of a ZC dizzy (if its DOHC).
Either way good luck man
That was hard to understand. No you can't use a ZC dohc distributor. No you can't use a 92+ but you can if you convert to OBD1. Its best if you get another A6 distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">That was hard to understand. </TD></TR></TABLE>
Word yo
Word yo
BuddhistPriest87
Aug 30, 2006 09:01 PM
BoostdRex
16
Nov 26, 2005 11:39 AM
