just bought 84 accord
Wow, 84? That's second generation if I'm not mistakin
. Performance parts are hard to find for a 2nd gen, you could probably do some DIY stuff like an intake.
AGX makes aftermarket struts for the 84-85 models. That's all I know.
EDIT: lowering springs - 1.3" for $229
http://www.modacar.com/product...rings/
trunk spoiler - $45
http://www.electrodyne.cc/Merc...41853
Neuspeed lowering springs - 1.5" for $215.96
http://www.electrodyne.cc/Merc....05.1
Sway bar kits
http://www.addco.net/products/honda.shtml
I couldn't really find any intakes or stuff for the motor. You'll have to make everything else.
Modified by riceburner247 at 2:32 PM 9/12/2004
trunk spoiler - $45
Sway bar kits
haha i had an 85 with an es2 motor.
you can get a weber on there or you can make a custom manifold to fit a 45 dcoe carb it really helps the overall performance of the car but you'll neet to cut a hole in your hood like i did. also you'll need to make your own headers or get some from an 88 accord. i built my own. alot of that emissions stuff can be ripped out also. and an 88 tranny will help you out as well but you'll need to change out the inner hubs. if you do plan on doing the dcoe set up you can add a turbo to it also i was running 5psi with no problems but i was running a bit rich. as for suspension parts you can canibalize some parts off of other late 80's accords i had awdiscs and 92integra seats.
o8EXLCoupe
Jul 27, 2008 08:25 PM
RobertNg
Dec 12, 2005 07:12 AM
Buhandi
Sep 24, 2003 11:21 AM
