What spark plugs to run with high compression
Old Dec 8, 2001 | 08:44 AM
RJL's Avatar
RJL
New User
Default What spark plugs to run with high compression
I need to know which plugs i should run with ctr pistons, preferbly NGK plugs. I have the NGK Rs but they are platinum
Old Dec 8, 2001 | 10:25 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: What spark plugs to run with high compression (Badboy01GSR)
A series 7 would work wonders for ya.
Like BKR7E's
Old Dec 8, 2001 | 10:32 AM
JSIR's Avatar
New User
you may want to try the iridiums, they are really strong plugs just in case you get a bit of detonation. But they are hard to find in heat range 7 from what I have seen. I don't think the platinum vs copper argument is worth paying attention to, I have never seen any gains by switching away from platinum plugs from any dyno testing I have done, the plats work as good as any. Personally I would try the Bosch F6DP, they work really well in high compression high heat applications. Some people may think these are cheap plugs , but they really work pretty nice, Larry Widmer swears by them too. Most importantly though, go to a smaller gap with whatever plug you choose, I would try .040"-.044" as a start, unless you upgrade to an aftermarket ignition. hth.
Joey
Old Dec 8, 2001 | 10:42 AM
RJL's Avatar
RJL
New User
Default Re: What spark plugs to run with high compression (JSIR)
i have the iridiums in my car now, but at normal heat range
Old Dec 8, 2001 | 10:46 AM
RJL's Avatar
RJL
New User
what website can i order the 7 series NGK plug, as no auto store by me has any
Old Dec 8, 2001 | 12:23 PM
TurboITR's Avatar
http://www.sparkplugs.com
Old Dec 8, 2001 | 01:15 PM
Zeus's Avatar
http://www.importreview.com/reviews/BoschVSNGK.html
...even the Larry hater likes them(Bosch Plat)... not bad for $1.99 a peice...
[Modified by Zeus, 2:16 PM 12/8/2001]
Old Dec 8, 2001 | 09:56 PM
Mike K's Avatar
Default Re: What spark plugs to run with high compression (Zeus)
Depends if you want platinum or not.
Platinum : PFR6G-11 or PFR6G-13 (11 and 13 are just different gaps)
Copper : BKR6E-N-11 or ZFR6F-11
Just go 6 heat range. Seems to me that less than 12.5:1 and 6 heat range is fine.
If you really want.. I have ITR platinum and coppers in 7 range.. and other equivalent plugs in both 7 and 8 heat range in stock.
Old Dec 8, 2001 | 10:22 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: What spark plugs to run with high compression (Mike K)
Bosch 4227, get the hint??????
Old Dec 8, 2001 | 11:51 PM
GokuSSJ4's Avatar
Default Re: What spark plugs to run with high compression (B18C-EJ1)
where can i get BKR7E'S in south cali ???
Old Dec 9, 2001 | 12:37 AM
Type Goch's Avatar
New User
Default Re: What spark plugs to run with high compression (Spoon1)
i think any auto place can order them for you. Where in so cali are you?
Old Dec 9, 2001 | 07:23 AM
Mike K's Avatar
Default Re: What spark plugs to run with high compression (Type Goch)
You can get BKR7E-N-11's from any Acura dealer.
Part number is 98079-5714J
Old Dec 9, 2001 | 07:38 AM
RJL's Avatar
RJL
New User
mike, i got a set of platinum NGK from acura, stock replacements
Old Dec 12, 2001 | 10:11 PM
GokuSSJ4's Avatar
L.A
sneakychaos
Nov 8, 2008 04:47 PM
em1si
Sep 3, 2007 12:23 PM
HondaCVT
Honda Fit
Jun 28, 2006 11:18 AM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
Westrock2000
Jan 26, 2003 09:58 AM
