friends not so fast car
Old Sep 11, 2004 | 03:04 PM
siblueg's Avatar
Default friends not so fast car
I have a friend that has a buch of money in go fast parts here's some of the parts off the top of my head, it's a 99 b16b with rs mach. stage 3 vtec cams, skunk 2 cam gears, arp head bolts, anr header, thermal catback, p28 program, adj fuel presure reg. and i sure alot of other stuff he's only dyno'ed 158 hp.[ i feel kind of sorry for him]. he's tried to tune i think but i'm wondering is there something else besides more tuning that needs to be done? any comments are appr.
Old Sep 11, 2004 | 06:55 PM
RynoDyno312's Avatar
Default Re: friends not so fast car (siblueg)
is his compression high enough to warrant stage 3 cams?
Old Sep 11, 2004 | 09:32 PM
rev-speed's Avatar
that is pretty sad
a stock b16b (civic type r makes more than 158)
i think he should put everything back to stock if its make it worst
and just get hondata and tune it
Old Sep 11, 2004 | 09:58 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: friends not so fast car (4cylinder)
It is probably in need of a good tuner.
Old Sep 12, 2004 | 09:17 AM
rev-speed's Avatar
ask ur boy what injectors is he running he may have put in a huge one and is runing too rich to make power
Old Sep 12, 2004 | 09:33 AM
EK22snatch
Guest
Posts: n/a
Default Re: (4cylinder)
yeah, theres definately something tuned incorrectly, but i also have to wonder, why stage THREE?
kinda foolish to spend so much money on a CTR engine if you are gonna mess with half of the **** in it anyways. just my 2cents..
Old Sep 13, 2004 | 02:48 PM
siblueg's Avatar
Default Re: (EK22snatch)
i think the injectors are stock, as far as compression, factory ctr stuff
i think he could only pull a 9.8 in the 1/8 mile and after the other stuff still a 9.8
thanks for your replies too
Old Sep 13, 2004 | 10:06 PM
rev-speed's Avatar
Default Re: (siblueg)
ask him and make sure hes on stock injectors and stock fuel pressure
Old Sep 14, 2004 | 06:29 AM
siblueg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblueg &raquo;</TD></TR><TR><TD CLASS="quote">i think the injectors are stock, as far as compression, factory ctr stuff
thanks for your replies too</TD></TR></TABLE>
Old Sep 14, 2004 | 09:04 AM
Cnote's Avatar
first who did the install?
second which program of P28 chip is he running?
who installed the cams?
which cams?
wondering if his valve springs are binded?
blah blah
Old Sep 14, 2004 | 10:16 AM
siblueg's Avatar
Default Re: friends not so fast car (Cnote)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cnote &raquo;</TD></TR><TR><TD CLASS="quote">first who did the install?
which cams?
blah blah</TD></TR></TABLE>
he did it himself
it's something like a vtec at 6000 and rev at 9500
he did it himself
rs machine stage 3
don't think so
Old Sep 23, 2004 | 01:52 PM
siblueg's Avatar
does anybody have any more replies
Old Sep 23, 2004 | 03:45 PM
reactiondc2's Avatar
just wondering,what kind of valve train is he runnin with those big cams?
Old Sep 23, 2004 | 04:21 PM
siblueg's Avatar
Default Re: friends not so fast car (reactiondc2)
i believe the rs mach. spring and retaners
Old Sep 25, 2004 | 09:27 PM
japspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblueg &raquo;</TD></TR><TR><TD CLASS="quote"> I have a friend that has a buch of money in go fast parts here's some of the parts off the top of my head, it's a 99 b16b with rs mach. stage 3 vtec cams, skunk 2 cam gears, arp head bolts, anr header, thermal catback, p28 program, adj fuel presure reg. and i sure alot of other stuff he's only dyno'ed 158 hp.[ i feel kind of sorry for him]. he's tried to tune i think but i'm wondering is there something else besides more tuning that needs to be done? any comments are appr.</TD></TR></TABLE>
I call BS on this. YOU know why his motor is only putting out 158hp is because Its probable fucked up. Now dont post up BS trying to make the b16b look bad and stop posting up your boys setup unless he asked you too.
Old Sep 25, 2004 | 10:40 PM
94dxt's Avatar
Default Re: friends not so fast car (japspec)
He's over caming
Old Sep 26, 2004 | 07:29 AM
Kamin's Avatar
Default Re: friends not so fast car (94dxt)
he is under tuning.
get that poor engine on a dyno with some kind of fuel adjusting device (VAFC) immediatley. a "chipped ecu" is way too ******* generic for a large cam setup like that.
Old Sep 26, 2004 | 08:04 AM
GaRn's Avatar
Default Re: friends not so fast car (Kamin)
he obviously needs a tune.. you cant run a setup like that without exstensive tuning..
Old Sep 26, 2004 | 08:32 AM
96_teck's Avatar
Default Re: friends not so fast car (RynoDyno312)
what compression would warrant stage 3 cams?
Old Sep 26, 2004 | 10:52 AM
Kamin's Avatar
Default Re: friends not so fast car (96_teck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96_teck &raquo;</TD></TR><TR><TD CLASS="quote">what compression would warrant stage 3 cams? </TD></TR></TABLE>
compression has almost no effect on anything to do with cam selection
Old Sep 26, 2004 | 04:02 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
compression has almost no effect on anything to do with cam selection</TD></TR></TABLE>
really? doesn't the dynamic compresion go down because of the extra overlap of big cams which you counter with higher static compression? So some really agressive NA cams will make more power then stock or stg1 cams even with like 9.0:1 compression? forgive my ignorance but I have read the exact opposite of what you stated.
Old Sep 26, 2004 | 04:55 PM
Kamin's Avatar
Default Re: friends not so fast car (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">really? doesn't the dynamic compresion go down because of the extra overlap of big cams which you counter with higher static compression? So some really agressive NA cams will make more power then stock or stg1 cams even with like 9.0:1 compression? forgive my ignorance but I have read the exact opposite of what you stated.</TD></TR></TABLE>
yes dynamic compression does change with overlap BUT static dosent. and im pretty sure the newbie asking dosent even know the difference let alone know how to choose the proper cams for a setup.
and a really agressive cam may not make you any power over a "stage 1" cam setup (wich i also find bullshit, stage 1 means nothing. give me lift, duration, centerlines, and overlap), you may loose power because the head can only flow so much air. ever used a flowbench? when you are trying to choose a cam/s you flow the head at specific valve lift points, at a certain point you reach max flow, if you go above max flow you loose flow because there is too much volume, not enough velocity. so when you flow the intake and exhaust ports you get an exact lift where you KNOW your engine will make the most power. from those flowbench numbers you can even estimate total engine horsepower potential within a couple actual hp. before ever building any engine you should flow your head(s) and build from around those numbers. flowbenches rule.
so in short static compression shouldnt play much of a role in cam selection, it should all be based on headflow numbers.
i hope that all made sense, its extremley hard to explain in 1 paragraph. i have pages of **** on this in my notbooks.
Modified by Kamin at 6:18 PM 9/26/2004
Modified by Kamin at 6:22 PM 9/26/2004
Old Sep 26, 2004 | 07:01 PM
siblueg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec &raquo;</TD></TR><TR><TD CLASS="quote">
I call BS on this. YOU know why his motor is only putting out 158hp is because Its probable fucked up. Now dont post up BS trying to make the b16b look bad and stop posting up your boys setup unless he asked you too. </TD></TR></TABLE>
wtf are you talking about i don't care what engine it is, i'm just trying to help a friend make his car faster and run right so you stop posting ***!
and every body thanks for all the replie's
Old Sep 26, 2004 | 09:27 PM
japspec's Avatar
and every body thanks for all the replie's</TD></TR></TABLE>\
With all those parts he should be doing better so do a compression check. Oh and call me a *** again and we can have an old fashion snap session.
Old Sep 27, 2004 | 04:24 PM
siblueg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec &raquo;</TD></TR><TR><TD CLASS="quote">\
With all those parts he should be doing better so do a compression check. Oh and call me a *** again and we can have an old fashion snap session. </TD></TR></TABLE>
ok internet gansta
