b16 swap
ok so im gonan go for a b16a1 complete swap. it comes with transmission, engine wiring harness, all the cables, ECU, distributor, complete intake manifold, alternator, A/C, power steering pump, all the brackets and sensors, and the shift linkage. it will be going in a 91 civic dx hatch. what other parts am i going to need for this swap? also if you have a b16 for sale and are in WA. let me know
The harness will be good for plugs since you will need to do a MPFI swap.
You also need a resistor box for the MPFI swap and some axles.
And as stated above motor mounts.
You dont have power steering so you dont need that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=*Dusk2Dawn*=- »</TD></TR><TR><TD CLASS="quote">Good Luck, and Don't Forget To Pray Before You TRY to turn on your CAR
Yup, LoL I did that
which it turned on
</TD></TR></TABLE>Yup, LoL I did that
which it turned on
