fuel rail
i was relieving my fuel pressure today and loosened the banjo bolt on the fuel rail . after i was finished i tightened back the bolt but i smelled gas and noticed that it was leaking gas around the banjo bolt area on the fuel rail . i dont know but is my bolt or washer bad ?! do i need to replace them ?! because it seems like these are the only things that is making it leak .
if so, could someone tell me what size the bolt/washer is ?! and is the only place i can purchase the bolt/washer at honda or can i buy it at a local hardware store like home depot ?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redxalien »</TD></TR><TR><TD CLASS="quote">i was relieving my fuel pressure today and loosened the banjo bolt on the fuel rail . after i was finished i tightened back the bolt but i smelled gas and noticed that it was leaking gas around the banjo bolt area on the fuel rail . i dont know but is my bolt or washer bad ?! do i need to replace them ?! because it seems like these are the only things that is making it leak .
if so, could someone tell me what size the bolt/washer is ?! and is the only place i can purchase the bolt/washer at honda or can i buy it at a local hardware store like home depot ?!</TD></TR></TABLE>
1- why were you relieving the Fuel pressure there? all you need to do is open the gas cap
2- how tight did you make it?
3- remove it and reinstall it. make sure that the washer sits properly. tighten it down a lot! if you arent flexing the engine then it isnt tight enough
civictype-r
May 26, 2010 08:30 AM
Accord15
Dec 9, 2002 02:04 PM
