bottom end ballencing w/ itr pistons
Old Sep 11, 2004 | 11:36 AM
rcurry14's Avatar
Default bottom end ballencing w/ itr pistons
I have read before that you can run itr pistons w/ a gsr crank and rods. The itr bottom end is heavier than the gsr bottom end so if you added itr pistons to the gsr bottom end wouldnt it throw the bottom end out of ballence?
Old Sep 11, 2004 | 01:09 PM
Hybrid96EK's Avatar
Default Re: bottom end ballencing w/ itr pistons (rcurry14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurry14 &raquo;</TD></TR><TR><TD CLASS="quote">I have read before that you can run itr pistons w/ a gsr crank and rods. The itr bottom end is heavier than the gsr bottom end so if you added itr pistons to the gsr bottom end wouldnt it throw the bottom end out of ballence?</TD></TR></TABLE>
Not sure of the source of your logic,but no. You will have no issues running this combo. This is the combo I will be running very shortly.
Old Sep 12, 2004 | 01:06 PM
rcurry14's Avatar
but the gsr pistons are matched for the gsr pistons and rods. The itr pistons are ballenced for the itr crank and rods.
Old Sep 12, 2004 | 04:10 PM
HondaMaster200's Avatar
Default Re: (rcurry14)
You will be fine using itr pistons with gsr rods. You can get the rods and pistons balanced together for more insurance, you should also do the crank. it dosent cost that much to get them all balanced.
Old Sep 12, 2004 | 04:33 PM
Tbone's Avatar
Balancing pistons is just making sure there all the same exact weight. Balancing rods is the same except you also end balance them to make sure they are the same weight end to end.
Old Sep 13, 2004 | 10:22 AM
hybrid_vtec's Avatar
Your Pistons should weigh around half the weight of your rods; and I believe that the ITR and GSR pistons aren't that different so I wouldn't worry!
ShawnR
Jan 5, 2006 08:10 AM
93gsrcoupe
Aug 5, 2004 07:54 PM
xplanetearth420x
May 26, 2004 10:41 PM
B18C-EJ1
May 24, 2002 04:37 PM
