Honda S2000 Honda S2000
15k maintenence - what is necessary?
Old Sep 11, 2004 | 08:10 AM
neo1z's Avatar
Default 15k maintenence - what is necessary?
I just wanted to know what is necessary, in your guys' opinions, for the 15k maintenence. I have the service manual, however, I want to know from you guys with experience what really is necessary, and what is a waste of time...thanks.
Old Sep 11, 2004 | 08:37 AM
PNB's Avatar
PNB
GatorNATION
Default Re: 15k maintenence - what is necessary? (neo1z)
I think that the only really important thing is to change your fluids, like the tranny, etc.
If you have a stock intake, get a new filter as well.
I don't know what is listed for the 15k mile maintenance, so if someone else could chime in, it would be a big help
Old Sep 11, 2004 | 11:07 AM
neo1z's Avatar
Default Re: 15k maintenence - what is necessary? (PNB)
Id appreciate the help.
Tranny and Diff fluids?
Old Sep 11, 2004 | 11:36 AM
Mr. Bagel's Avatar
oil change,
diff fluid change (whatever your preference, personally I prefer swepco)
tranny fliud change (honda MTF)
inspect pads, both in and out to check for excessive wear
inspect filter, replace if necessary
inspect tire wear, especially on stock rears (I'd be surprised if they lasted that long)
Old Sep 11, 2004 | 11:55 AM
Nishant's Avatar
Default Re: 15k maintenence - what is necessary? (Mr. Bagel)
if you drive hard, changing brake fluid won't be a bad idea either
Old Sep 11, 2004 | 11:57 AM
neo1z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">oil change,
inspect tire wear, especially on stock rears (I'd be surprised if they lasted that long)</TD></TR></TABLE>
Yup, already replaced those tires. They were SCARY in the rain.
I dont auto-x or anything like that yet....I dont anticipate my pads needing a change, no fade either.
Old Sep 11, 2004 | 12:02 PM
Mr. Bagel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">I dont auto-x or anything like that yet....I dont anticipate my pads needing a change, no fade either.</TD></TR></TABLE>
fade doesn't come from worn pads. fade comes from overheating the brakes which typically occur on a track. even if you autocrossed the car, you shouldn't feel fade one bit, unless it is an extremely long autocross where the brakes are tasked to a point they never get to cool down.
you are just looking for the amount of pad there. which I'm sure is fine, but when you get a chance, remove the wheels and look at the inner pad. you should be able to see if there is plenty left.
Old Sep 11, 2004 | 12:20 PM
neo1z's Avatar
lol - I didnt really mean fade as one would feel while driving hard - I dont notice anything abnormal with my brakes. I suppose Ill snoop around down there anyway, I need to install some Konis here at one point coming up anyway.
Old Sep 13, 2004 | 09:50 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNB &raquo;</TD></TR><TR><TD CLASS="quote">I think that the only really important thing is to change your fluids, like the tranny, etc.
I don't know what is listed for the 15k mile maintenance, so if someone else could chime in, it would be a big help </TD></TR></TABLE>
replacing the air filter isn't necessary that soon unless you drive in construction like conditions.
Old Sep 13, 2004 | 05:55 PM
neo1z's Avatar
Default Re: 15k maintenence - what is necessary? (vapor)
Appreciated fellas.
Old Sep 14, 2004 | 07:44 AM
boosted1993's Avatar
good info.........
Old Sep 14, 2004 | 09:26 AM
GradyDC5's Avatar
Yah, my tires were all most completely bald. Driving at 40 miles an hour the car would drive it's self.
Old Sep 15, 2004 | 12:22 PM
Default Re: (ReallySlowEg)
they are a 15k mile tire so they will go quickly on a S2k
Old Sep 16, 2004 | 07:28 PM
Nishant's Avatar
Default Re: (boosted1993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted1993 &raquo;</TD></TR><TR><TD CLASS="quote">they are a 15k mile tire so they will go quickly on a S2k </TD></TR></TABLE>
especially the rears
Old Sep 17, 2004 | 07:10 AM
Default Re: (Nishant)
yes, I work at a honda dealer and people come in wanting to know why the hell there s2k is all over the place....... duh the tires are about to blow out
Old Sep 19, 2004 | 12:39 AM
evil vapor's Avatar
some go through them every 5k miles, I think I've seen a few get 20k out of them.
Old Sep 29, 2004 | 10:22 AM
eMpAtHy's Avatar
u should change tranny fluid every other oil change. so, for 2 oil changes..do 1 tranny fluid change. just my 2 cents.
Old Sep 30, 2004 | 09:48 AM
blacks2000's Avatar
Default Re: 15k maintenence - what is necessary? (eMpAtHy)
What about the 30k service? Can someone post up whats involved? I need to do that real soon...
Old Sep 30, 2004 | 05:07 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">u should change tranny fluid every other oil change. so, for 2 oil changes..do 1 tranny fluid change. just my 2 cents.</TD></TR></TABLE>
that's too often, with proper shifting techniques, the honda MTL fluid will last a long time, over 10k miles. I'd change it every 15k miles or once a year. I'd be more concerned with flushing/replacing the clutch fluid over the tranny fluid.
nukem384
Mar 16, 2010 07:20 AM
Easyslider01
Honda S2000
16
Mar 12, 2007 07:44 PM
sony224422
Feb 20, 2006 03:54 PM
00accordguy
Dec 9, 2005 05:09 AM
Gump
Jan 8, 2002 11:17 AM
