my crx died on me and wont start again
Old Sep 11, 2004 | 07:06 AM
blakryder1's Avatar
Default my crx died on me and wont start again
i have an 89 crx with the 1.5L and the other day it died and wont start back up. it cranks over and is gettin fuel, but it doesnt seem to be getting spark. i changed the coil, and cap, and button, but no difference, i also checked the plugs, none r burn or anything, im goin to go change the ignition module here in a bit, i was just wonderin if anyone had any clue what the hell is goin on with it. i also checked the ecu code and the only getting on flash. so things seem good there. any help would be great
Old Sep 11, 2004 | 08:30 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: my crx died on me and wont start again (blakryder1)
it probably needs a dizzy. if you werent getting fuel, id say main relay. but it sounds like an ignition problem to me.
Old Sep 11, 2004 | 10:00 AM
crx_88_si's Avatar
any check engine lights?
Old Sep 11, 2004 | 10:04 AM
spaceman's Avatar
its sounds electrical to me..need new distributor probably..check your timing maybe it changed somehow..it also could be the alternator..did the battery light come on?
persianp
Jun 8, 2010 06:02 PM
Andrew111385
Apr 3, 2007 08:26 PM
hyabusa hunter
Jul 6, 2006 08:51 AM
rob42386
Sep 30, 2005 12:42 PM
bmg123
Sep 25, 2005 12:33 AM
