who is using a T3 .42 .48 turbo or similar on a d or b series let me know!!!!
just picked up this turbo for a great deal and what to know what kind of power people are making with this turbo. I hope I can geat a broader more usable powerband than going with the super 60.
i was using the saab turbo .42.48 turbo on my sohc. i made like 227whp and 207lbs torque at 12 psi. with the aid of my skunk2 im
what do you mean which compressor wheel.
mine is the sabb turbo just like the other guy mentioned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic »</TD></TR><TR><TD CLASS="quote">i was using the saab turbo .42.48 turbo on my sohc. i made like 227whp and 207lbs torque at 12 psi. with the aid of my skunk2 im
My b16 made like 180whp with 9psi
....it's a great turbo for a sohc not so great for a dohc.......
My d15 pulled as hard (at 10spi) as my b16 did at 7psi (same turbo).......needless to say I upgraded and found a whole new world.....power
</TD></TR></TABLE>My b16 made like 180whp with 9psi
....it's a great turbo for a sohc not so great for a dohc.......My d15 pulled as hard (at 10spi) as my b16 did at 7psi (same turbo).......needless to say I upgraded and found a whole new world.....power
so its a good turbo for the sohc then. I am hopping to get quick spool up and a nice broad power band compared to the big peaky turbos.
I think its always better to have less peak and more usable power for overall driveability
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo »</TD></TR><TR><TD CLASS="quote">so its a good turbo for the sohc then. I am hopping to get quick spool up and a nice broad power band compared to the big peaky turbos.
I think its always better to have less peak and more usable power for overall driveability</TD></TR></TABLE>
IMO it's a perfect match for a sohc. It's a little larger then the turbo's that come with the greddy sohc kit so you should make a little more peak power. That t3 is to a sohc what a t3t4 (drag specs) is to a dohc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
IMO it's a perfect match for a sohc. It's a little larger then the turbo's that come with the greddy sohc kit so you should make a little more peak power. That t3 is to a sohc what a t3t4 (drag specs) is to a dohc.</TD></TR></TABLE>
really great way to put it.
Saab T3 is probably .50 trim unit. Some of the early ones were .45 trim. It's a good street unit for SOHC or LS, especially in a light chassis.
No way you'd get a broader power range out of it than a regular .60 trim T3... FYI, most people get .60 trim and Super 60 confused - Super 60 is a good bump in power over .60 trim OEM, just like .60 trim is a good bump in power over .50 trim.
Since you already have the Saab unit, just put your car together and run it. Anything you care to upgrade to by way of bigger T3 and T3/04 only directly bolt in place... I see too many people obsessing over every last detail instead of making their car run and enjoying it.
I've never heard a 60trim t3 referred to as a 'big peaky turbo'. You need to drive one before you make claims like that. And I agree with jdavis on the 50 trim not making a broad power band. Mine pulls nice up top but defiantly flattens out compared to a 60 trim on the same motor. I'm putting on a 60 trim soon because the 50trim is too small to make a nice powerband IMO.
I have no idea what power I make with mine. it pulls hard from 4-7000 but the meat of it is between 4500-6000. I can hang with some 600cc street bikes as a reference. So ya, just put it on and try it...
Modified by Bailhatch at 1:53 PM 9/13/2004
hey bailhatch: have you gone to the strip with your setup yet? and did you make your own uberdata map.
i will be modifying beerbongs map and altering it with a wideband.
and how much boost are you running?
Im running a Garrett/Airesearch T3 .48/.42 on my d16y7 motor.. Im not sure on the power but the times are below in my sig..
awsome times, if I can pull low 13's like that in my dx hatch on 12lbs I would be happy
daily driver with full interior, I take the sub box out when I go to the track.
I was gutted at one point, but could hardy tell a difference in speed with the leather seats put back in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo »</TD></TR><TR><TD CLASS="quote">daily driver with full interior, I take the sub box out when I go to the track.
I was gutted at one point, but could hardy tell a difference in speed with the leather seats put back in</TD></TR></TABLE>
Cool.. What engine do you have in the hatch right now?
here ya go. T3 .42/.48 off a chrysler lebaron in the junkyard. 7psi on a bone stock ITR motor. Also as you can see this was untuned. Car did eventually make 280hp and 206ftlbs at 11psi.
scott
scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo »</TD></TR><TR><TD CLASS="quote">hey bailhatch: have you gone to the strip with your setup yet? and did you make your own uberdata map.
Never drag raced it. I want to wait for my built block and to build my traction bars since I will probably only go once a summer. I'ts primarily set up for street and auto-x although I do run a pretty agressive unsprung 6 puck.
Yup I have done uberdata on a few cars. I tune the fuel with a PLX m300. Why are you using someones map to start? I always just do the 'how to make a basemap' thing on the uberdata site. Pretty much every car has started off nice and safe with afrs in the low 11s or high 10s using the basemap method.
and how much boost are you running?</TD></TR></TABLE>
11psi
I'm impressed with the power you guys are making!
the curve of scooters dyno is pretty much what mine feels like (not respective of rpm of course)...good rise of power then flattens but doesn't fall up top. I hope the 60 trim keeps going a little higher and doesn't flatten out. My turbine housing is a .63 with some mild smoothing and gasket matching so it should work for my needs...until the HX30 get thrown on that is
Modified by Bailhatch at 12:05 AM 9/14/2004
11psi
whats the ball park range for a new or rebuilt T3 .48/.42?
where do you guys suggest i look? ive been looking on ebay alot lately and maybe i can just wait for a deal to come up there. but any other ideas?
the more i research set ups with this turbo on the D the more i like
so yea im asking how much (ballpark) and where to look....
thnx guys
thnx guys
