what speakers should i go w/.
Old Sep 10, 2004 | 10:29 PM
alexngo's Avatar
Default what speakers should i go w/.
i have a 01 integra and i just recently purchased a eclipse titanium 15" sub w/ phoenix gold 1000w amp for under 600 and i was wondering what kind of speakers you guys would recommend w/ this setup.
Old Sep 11, 2004 | 04:27 AM
drkblue_civic's Avatar
Default Re: what speakers should i go w/. (alexngo)
throw a nice set of components up front and then a decent set of aftermarket ones in the back with a fairly priced 4 channel and you will be all set.......i would suggest something like infinity speakers for value and sound quality
Old Sep 11, 2004 | 06:28 AM
Xsi's Avatar
Xsi
You have a 15 inch sub so I would suggest a nice quality pair of components up front and a reasonably powerful 2 channel or a bridged 4 channel amp. Try a few out and see what you like. Personally I'd ditch the rear speakers.
Old Sep 12, 2004 | 11:33 AM
EBP_SI's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">You have a 15 inch sub so I would suggest a nice quality pair of components up front and a reasonably powerful 2 channel or a bridged 4 channel amp. Try a few out and see what you like. Personally I'd ditch the rear speakers.</TD></TR></TABLE>
agreed...how much are you planning on spending?
Old Sep 12, 2004 | 12:04 PM
archmage's Avatar
For about $225:
Alpine SPX-177r (NO, I have not heard these...I'll admit it. But, from a trusted source, these are a GREAT value). I'm going to recommend sticking with these unless your install is somewhat thorough. If you are mounting in the doors, or your kickpanels are less than sturdy...or you don't have enough airspace (sealed) in your kicks - then don't even bother with more expensive components.
If I wanted a budget setup...I'd go for these.
Now I see that you have fairly high-output bass... You'd probably want a fuller midbass, correct? Hmm... Resonant Engineering will soon release their "XXX" components. I think the target price is somewhere around 400-500. I'm not at all sure what the tweeter will be like, but I'm personally waiting for that Mid! (It's huge!) http://www.reaudio.com -- Don't hold your breath - might be delayed for a while.
Assuming you don't care for that kind of SPL... a lot of people love Seas Lotus Reference components. These ARE excellent (And yes, this time I'm allowed to say that). If the XXX mid doesn't perform the way I want, I'll be going with a Seas Lotus 8" midbass. These are a little more costly...a little more difficult to set up...and perhaps you should use a different tweeter (not the seas lotus tweet). Ask for advice before purchasing these - the Mid needs a "notch filter" - pain in the ***, but beautiful when done. Might want a 3-way system if going with the 8" - use lotus 4" mid. I have different plans in mind.
There - gave you 3 different budget points with 3 different goals in mind.
Edit: And I'm going to suggest ditching the rear-fill, or simply fading it down (a lot) so you can use stock rears and headunit power. I'd prefer eliminating it though
prabtej_si
Audio / Security / Video
Jan 31, 2005 07:34 AM
AaronJ
Apr 1, 2004 01:10 PM
okman16
Oct 11, 2003 09:10 PM
FatJoe
Oct 5, 2003 10:12 AM
SSBP DC2
Apr 18, 2003 12:22 AM
