when dose the bc cams like the vtec?
Old Sep 10, 2004 | 10:04 PM
my ride's Avatar
Default when dose the bc cams like the vtec?
what is the best rpm for vtec with the buddy club cams? some cams like it high and some likes it lower than others. i got mys set at 4500 rpm, is that good? c/r is 12.1-1.
Old Sep 10, 2004 | 10:24 PM
rodrez.'s Avatar
Default Re: when dose the bc cams like the vtec? (my ride)
Every motor is different. Dyno is the best way to determine where to set your crossover.
Old Sep 10, 2004 | 11:15 PM
Team 4's Avatar
Default Re: when dose the bc cams like the vtec? (rodrez)
I set mine at 6000, and the transition is very smooth. Too smooth actually.
Old Sep 10, 2004 | 11:38 PM
Combustion Contraption's Avatar
higher lift, longer duration cams usually like the xover higher, because the engine is 'ingesting' enough air at these high speeds to actually make use of the large lobes.
killabs
Apr 8, 2008 09:24 AM
JinMTVT
12
Dec 21, 2004 08:31 PM
RayB
Aug 11, 2003 02:54 PM
quick
Jul 18, 2003 08:18 AM
