cryo treating crank...before or after balancing
Old Sep 10, 2004 | 08:39 PM
fastludeh22's Avatar
Default cryo treating crank...before or after balancing
i was thinking of cryo treating it first, then having balanced. just wanted some other opinions.
edit: anyone ever cryo bearings?
Modified by fastludeh22 at 12:56 AM 9/11/2004
Modified by fastludeh22 at 5:49 PM 9/11/2004
Old Sep 11, 2004 | 03:20 PM
LudeyKrus's Avatar
Cryo it after you balance the bottom end.
Also, you can pretty much cryo everything in the motor, including the block and head.
Old Sep 11, 2004 | 06:01 PM
Rick Solis's Avatar
Default Re: (LudeyKrus)
cryo first, balance second...
Old Sep 11, 2004 | 06:33 PM
Shakes's Avatar
space cadet
Default Re: (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">cryo first, balance second...</TD></TR></TABLE>
why?
wouldnt you want to balance it first then streinghten it? rather then streingthen it then go grinding on it?
Old Sep 11, 2004 | 07:17 PM
Matgallis's Avatar
Default Re: (Shakes)
i'm sure strengthing it will cause inperfections on the balance. Cyro treat then balance
Old Sep 11, 2004 | 09:31 PM
95ONE's Avatar
Default Re: (Matgallis)
No. Balance, then Cryo.
Lets fight.
Old Sep 11, 2004 | 09:39 PM
Eddiebx's Avatar
y not skip the cryo and balance it and call it a day
Old Sep 11, 2004 | 10:23 PM
porkchop's Avatar
I'm up for a good fight.
Freeze 'em, then balance 'em. End of discussion, talk to the hand.
As for bearings... no cryo, but you can coat them.
http://www.swaintech.com (most popular)
http://www.calicocoatings.com
http://www.polydyn.com
As for cryogenically freezing, any other company besides DEEP FREEZE? http://host58.ipowerweb.com/~deepfree/home.htm
All this stuff is pretty interesting. Anything we should NOT treat?
Old Sep 11, 2004 | 10:47 PM
Default Re: (porkchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">y not skip the cryo and balance it and call it a day </TD></TR></TABLE>
cause this is going in a high boost h23 vtec. i dont feel like breaking a crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porkchop &raquo;</TD></TR><TR><TD CLASS="quote">As for bearings... no cryo, but you can coat them.
All this stuff is pretty interesting. Anything we should NOT treat?</TD></TR></TABLE>
i saw something about bearing on this site is why i ask:
http://www.metal-wear.com/racing.htm
ill look into coatings also...but wouldnt that affect clearences?
Old Sep 14, 2004 | 04:17 PM
porkchop's Avatar
Default Re: (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
ill look into coatings also...but wouldnt that affect clearences?</TD></TR></TABLE>
i know of people getting top and sides of pistons done from swaintech, gears in transmissions, but bearings I don't know.
The Calico link I put above looks like they sell you their own treated bearings (probably compensating for clearances), not sure if they have your application, you'd have to call them.
Call cryogenic processing companies like the one you linked and ask them if bearings can be done, I personally don't think I'd mess with them, they're supposed to be able to wear, not the rods.
Old Sep 14, 2004 | 05:34 PM
kb58's Avatar
Banned
Answer this: Does cryo changes the shape of the part?
Yes: Balance afterward.
No: Balance before.
DeeCeeTwo
Nov 14, 2007 06:10 PM
Aarron_M
Jun 12, 2007 06:19 PM
ek four
Nov 20, 2005 01:47 PM
