water pump leaking - chevy astro
there seems to be water leaking from the water pump, like a steady stream. are water pumps suppose to have holes in them so when they fail, water leaks out? because it looks as if it's leaking from a hole on the bottom of the water pump, and the whole is meant to be there. has this ever happened to any of you?
