Whee! finally got my dyno graph.
Old Sep 10, 2004 | 12:49 PM
Chris F's Avatar
Default Whee! finally got my dyno graph. (ITR Turbo!)
Greddy 18G turbo, external WG. 550CC injectors. Hondata. Stock motor.
Running about 11.2-11.5:1 A/F. 10 PSI.
Edit: Mods list:
Greddy kit, stock downpipe, wg held closed.
Greddy intercooler.
Type S BOV
Tial 38MM WG with open dump tube
~2" test pipe (same as entry/exit small diameter of stock cat, and greddy DP.
Tanabe Racing Medallion exhaust, no silencer.
550CC RC injectors.
Hondata s100b
BKR7E plugs
190 Walbrow fuel pump
Profec B Spec 2 boost controller.
Stock motor, stock TB, stock intake manifold, stock ignition, stock ignition wires and dizzy, stock FPR, stock fuel rail, etc. (original 1998 parts).
Modified by ccfries at 3:20 PM 9/11/2004
Old Sep 10, 2004 | 02:08 PM
hulkhb's Avatar
upgrade that turbo for insane numbers. nice work none the less man.
Old Sep 10, 2004 | 02:17 PM
Chris F's Avatar
Default Re: (hulkhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb &raquo;</TD></TR><TR><TD CLASS="quote">upgrade that turbo for insane numbers..</TD></TR></TABLE>
Ha! On a stock motor I wouldn't really want to make much more. Plus I like my midrange torque right where it is. I adjusted the boost controller some, it actually spools faster now than on the dyno graph.
-Chris
Old Sep 10, 2004 | 02:23 PM
CWTegRNo.160's Avatar
Default Re: (ccfries)
nice! good #'s
Old Sep 10, 2004 | 02:28 PM
B2FiNiTY's Avatar
Default Re: (CWTegRNo.160)
That looks like some nice usable power
Old Sep 10, 2004 | 02:35 PM
hulkhb's Avatar
Default Re: (B2FiNiTY)
thats the thing less boost with a larger turbo you'll make the same numbers, if not more
Old Sep 10, 2004 | 02:43 PM
csufweed's Avatar
nice numbers, hows traction treating ya?
Old Sep 10, 2004 | 02:47 PM
Chris F's Avatar
Default Re: (csufweed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csufweed &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers, hows traction treating ya?</TD></TR></TABLE>
1st gear is silly. 2nd gear is kinda silly, I lose traction sometimes at 4K, sometimes at 6K. 3rd on up is fine.
I seriously haven't had the opportunity to launch the car yet, so I don't even know how I'd do it on street tires. I do pound on it in 2nd gear and let the tires spin though. That's fun, good stress relief pulling out of work.
On autoX tires, 3rd gear should be reasonable at an HPDE, but most corners I can just stay in 4th and ride the 4000RPM torque curve.
(I haven't done an HPDE at this boost yet, just at my measly 5 PSI 210 WHP setup.)
-Chris
Old Sep 10, 2004 | 04:25 PM
Black R's Avatar
25 Year Member
Default Re: Whee! finally got my dyno graph. (ccfries)
Please post ALL of your mods please!
I'm interested in the downpipe, cat, and exhaust size you're running.
Also, you're using an EXTERNAL wastegate with the greddy kit?
How did you manage that?!
I have the same kit and am trying to do the EXACT same thing. 300whp is the goal on stock motor.
Send me your hondata map!!!
Old Sep 10, 2004 | 05:01 PM
Chris F's Avatar
Default Re: Whee! finally got my dyno graph. (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
Send me your hondata map!!! </TD></TR></TABLE>
Dude, I know! Suprdave with the suprtune is being stingy
Full list of mods (HP-related)
Greddy intercooler.
Type S BOV
550CC RC injectors.
Hondata s100b
BKR7E plugs
Old Sep 10, 2004 | 05:07 PM
Misfit's Avatar
Nice numbers.... I too am now boosted with 11:1 CR. I am using custom stuff with a SC61 turbo.
&lt;----- Wants a GT28RS turbo for fatter midrange and quicker spool times
Old Sep 10, 2004 | 05:25 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">Dude, I know! Suprdave with the suprtune is being stingy
Greddy intercooler.
Type S BOV
550CC RC injectors.
Hondata s100b
BKR7E plugs
Stock motor, stock TB, stock intake manifold, stock ignition, stock ignition wires and dizzy, stock FPR, stock fuel rail, etc. (original 1998 parts). </TD></TR></TABLE>
for using all those OEM R parts
Old Sep 10, 2004 | 05:49 PM
Black R's Avatar
25 Year Member
Greddy intercooler.
Type S BOV
.....not a bash, but why is the wastegate held closed and you are using an external TIAL unit? Is there an inherent deficiency in the stock internal wastegate?
Also, which greddy intercooler? What are the dimensions, if you don't mind my asking.....?
Huge props for doing this with the small *** downpipe that the turbo kit comes with!
At what rpm does full boost come on, btw?
*edit*
Why the 550cc injectors? Would you be maxing out say 450cc ones?
And what psi base fuel pressure? Would you be killing the stock fuel pump otherwise?
Old Sep 10, 2004 | 06:29 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....not a bash, but why is the wastegate held closed and you are using an external TIAL unit? Is there an inherent deficiency in the stock internal wastegate?
I couldn't hold steady boost with internal WG. It spiked hard at around 5500 RPM, even with the boost controller off. We gave up and didn't ever take it past 6000 RPM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">Also, which greddy intercooler? What are the dimensions, if you don't mind my asking.....?
The large one, I think this is it.
94-99 Acura Integra GSR/LS/RS 2 row Front Mount Type 24V - fits Greddy Turbo kit only
adjusted boost controller since the dyno, now I get full boost before 4000 RPM
And what psi base fuel pressure? Would you be killing the stock fuel pump otherwise? </TD></TR></TABLE>
550 because they cost the same as 440. No harm, idle is fine.
FPR is stock (read!). Fuel pump is 190 LPH Walbro (read!). haha.
-Chris
Old Sep 10, 2004 | 07:04 PM
Nishant's Avatar
#'s look good, esp midrange torque
Old Sep 11, 2004 | 03:13 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Nice numbers Chris!
Are you also running the pipsqueek sized piping that came with the kit to produce those numbers?
Old Sep 11, 2004 | 03:22 AM
DontBlink's Avatar
Default Re: Whee! finally got my dyno graph. (Nvious R)
real nice number for the greddy kit
Old Sep 11, 2004 | 03:23 AM
Nvious R's Avatar
Default Re: Whee! finally got my dyno graph. (DontBlink)
you running the same kit?
Old Sep 11, 2004 | 03:29 AM
DontBlink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">you running the same kit?
if your asking me, no.
Old Sep 11, 2004 | 03:30 AM
Nvious R's Avatar
Old Sep 11, 2004 | 07:09 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers Chris!
Are you also running the pipsqueek sized piping that came with the kit to produce those numbers?</TD></TR></TABLE>
Yeah, no changes to the piping of the kit (charge pipes, downpipe, etc.)
Although I DID make one minor change, I cut the restrictor plate off of the intake (by the filter). Dremel &gt; Greddy.
-Chris
Old Sep 11, 2004 | 09:10 AM
Bbasso's Avatar
Why is the power lines so choppy? --- Noobie Q...
Old Sep 11, 2004 | 09:29 AM
vtec.dc2's Avatar
Default Re: Whee! finally got my dyno graph. (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Why is the power lines so choppy? --- Noobie Q...</TD></TR></TABLE>
running rich.. and/or dyno graph output option wasn't selected to show the smoothest line.
Old Sep 11, 2004 | 09:32 AM
vtec.dc2's Avatar
nice numbers.. btw!
Old Sep 11, 2004 | 03:50 PM
Chris F's Avatar
Default Re: Whee! finally got my dyno graph. (vtec.dc2)
UPDATE hidden in an edit
My turbo sounds like total crap. I have a lot of shaft play and the exhaust turbine is hitting the housing. I plan to blow this one up while shopping for a new one.
Stand by for updates
-Chris
Modified by Chris F at 6:44 PM 3/25/2005
