Spark Plugs
Old Sep 10, 2004 | 12:16 PM
mattEG's Avatar
Default Spark Plugs
So I'm going to start up the beast for the first time tommorow and I'm wondering what I should gap my spark plugs at.
I'm only going to be running ~7psi for the time being. What do you guys run?
Setup:
te04h turbo
log manifold
2.5" charge piping
d15b7 w/ uberdata
450cc dsm's
So yea, what do you guys run?
Old Sep 10, 2004 | 12:19 PM
wisjdmhonda's Avatar
Default Re: Spark Plugs (mattEG)
gapped mine at .28
Old Sep 10, 2004 | 12:42 PM
mattEG's Avatar
Can anyone explain gap at all? I'm a tad confused.
Old Sep 10, 2004 | 05:40 PM
Street Ghost's Avatar
Default Re: (mattEG)
I'm running BKRE7's gapped at .030" and them seem to be fine.
You want to run a small gap on a turbo spark plug to reduce the chance of the spark being blown out from boosting.
Old Sep 13, 2004 | 07:26 AM
mattEG's Avatar
SO the stock plug for the d15b7 is the zfr5f11
I'm wondering if NGK makes ZFR6F11's? As i understand that would be one step colder?
I can't seem to find any colder plugs in my area. Suggestions?
Old Sep 13, 2004 | 07:31 AM
Muckman's Avatar
Moderator in Chief
Your going to have to special order them. Stay away from platnum and iridium plugs on a boosted car.
https://honda-tech.com/zerothread?id=510127
Old Sep 13, 2004 | 08:20 AM
Mikes01GSR's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Your going to have to special order them. Stay away from platnum and iridium plugs on a boosted car.
https://honda-tech.com/zerothread?id=510127</TD></TR></TABLE>
I still don't understand why you can't use iridium's, they have a higher heat
rating then the v-powers. I understand that copper is a better conductor but
with the smaller point and the correct heat range I can't see the spark
being that much different. Is there actual proof of why not to? Or is it hear
say?
Old Sep 13, 2004 | 05:11 PM
Mikes01GSR's Avatar
Default Re: (Mikes01GSR)
anyone??
Old Sep 13, 2004 | 06:47 PM
A.RODD's Avatar
use ngk bcpr-7es,they work great.....
Old Sep 14, 2004 | 07:04 AM
Overblown-Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">
say?</TD></TR></TABLE>
I know you don't use the platinum becuase it gets super hot and can cause detonation. I would imagine that iridium is the same way. The reason they work so good is how hot they get.
Old Sep 14, 2004 | 07:06 AM
drvfast's Avatar
I run BKRE7's and they are gapped at .28.
Old Sep 14, 2004 | 07:29 AM
310whp@12psi's Avatar
got some BKR7E.s and gapped at same magical .28
but I might try the bcpr-7es like AL.RODD said
Old Sep 14, 2004 | 07:34 AM
RA166E's Avatar
I'm running NGK R5671A-10 Gap at .028
Old Sep 14, 2004 | 08:14 AM
Mikes01GSR's Avatar
Default Re: (Overblown-Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">
I know you don't use the platinum becuase it gets super hot and can cause detonation. I would imagine that iridium is the same way. The reason they work so good is how hot they get. </TD></TR></TABLE>
But the iridiums are made for hot applications the heat rating is alot higher
then the standard ngk's.
Old Sep 14, 2004 | 09:22 AM
then the standard ngk's.</TD></TR></TABLE>
Right so are the platinum. The problem is the tip gets really hot. It becomes a hot spot in the combustion chamber and can cause detonation.
tundra2000
Sep 22, 2010 05:51 AM
lilintegra25
Jan 16, 2007 07:52 PM
mattmw88
Feb 22, 2002 07:54 AM
