Quick question on starter and alternator....
Old Sep 10, 2004 | 11:30 AM
Ddep1085's Avatar
Default Quick question on starter and alternator....
my car takes a while to catch when i start it...the battery was just replaced so its got to be either the alternator or the starter...and i'm pretty sure both have over 50k on them (however might be less)
how much are the parts / labor on these type of things and is there an easy way to check where the problem actually is...
anyway, thanks a lot for checkin out my thread
Old Oct 21, 2004 | 07:19 AM
Quade's Avatar
Default Re: Quick question on starter and alternator.... (Ddep1085)
did you get this solved? What was it?
Old Oct 21, 2004 | 08:32 AM
Elkins911's Avatar
Default Re: Quick question on starter and alternator.... (Quade)
get them checked at a pepboys or kragen. if its not catching, then it has to do with your starter of flywheel
Old Oct 21, 2004 | 09:51 AM
Daemione's Avatar
Default Re: Quick question on starter and alternator.... (Elkins911)
The alternator has no impact on starting . . . . and as long as the car is cranking strongly, it's not your battery or starter.
How long has it been since you replaced all the various ignition components? Worn plugs, wires, cap, rotor, whatever, will all make starting more difficult for your car.
elmejor
Nov 6, 2008 07:12 AM
Fook_me_honda
May 13, 2007 10:34 PM
Accordboy27
Apr 5, 2006 06:04 PM
01-0720
Feb 3, 2005 04:23 PM
int3gra
May 16, 2002 08:51 AM
