H23 -> H22 Swap :: What do I do with the plug that went here ?
Ok, in the above pic (of my H22A) to the left of the dizzy is the green plug - I think this is vtec oil pressure sensor ?
To the right of the dizzy is the upper rad hose connector. On that connector is a plug, that on the H23 used to have a sensor in it ...
I had the plug from the H23 sensor on the coolant line going into the green plug by the ? vtec selenoid ? .. . .. it turned the fan on when the key went to accessory ..
.. uhh .. what do I do ?
that green plug is the vtec oil presusre sensor.
and i assume the other plug you are talkig abotu is int eh coolant neck, you could jstu swpa the one witrh teh sensor off the h23 block and plug the sensor in that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">That green plug is the vtec oil pressure sensor. I assume the other plug you are talking about is in the coolant neck. You could just swap the one with the sensor off the h23 block and plug the sensor in that way.</TD></TR></TABLE>
corrected some of your spelling.
hahaha...
hahaha...
Styler93GSX
Oct 22, 2005 02:42 AM
