Changing my Integra's A/C a-pipe, what do i need to know?
Old Sep 10, 2004 | 08:46 AM
phish's Avatar
Default Changing my Integra's A/C a-pipe, what do i need to know?
I'll be changing the A-pipe on my integra's a/c system today because it's leaking pretty bad and I'd like to know what I should know before I do this...
I'm pretty much thinking of unscrewing the pipe from both ends, putting the new one in, and then getting a R134a rechange system from autozone. Is it as simple as it looks? I have absolutely no clue on how the recharge works...could someone chime in? Thanks.
Old Sep 10, 2004 | 08:59 AM
JimBlake's Avatar
Default Re: Changing my Integra's A/C a-pipe, what do i need to know? (phish)
The part you're missing is evacuating the system before recharging. The recharge kits are sorta OK to add refrigerant to a system with a real slow leak.
But when you disconnect the pipe air gets in there. The air has to be completely removed (with a vacuum pump), otherwise it won't work real well.
Old Sep 10, 2004 | 09:05 AM
phish's Avatar
So do you suggest I replace the part and then take it to mechanic? Or just bring the part to the mechanic and have him do everything? Seems like I'm sort of stuck here...
Old Sep 10, 2004 | 09:36 AM
JimBlake's Avatar
Default Re: (phish)
Well, you could spend a couple hundred $$ on a vacuum pump...
Did you already buy the pipe? If so, some mechanics don't like you to bring your own parts. I guess I'd put in the pipe & then go to an AC shop for evac. & fill.
Old Sep 10, 2004 | 09:40 AM
deejaycherub's Avatar
Default Re: Changing my Integra's A/C a-pipe, what do i need to know? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The part you're missing is evacuating the system before recharging. The recharge kits are sorta OK to add refrigerant to a system with a real slow leak.
Absolutelyyyy CORRECTT-A-MUNDO..
drumminforev
616
Jul 5, 2018 11:31 AM
T:rex
Jul 14, 2009 08:56 PM
oldschoolcivic
Aug 27, 2008 12:32 AM
DireFire34
11
Jul 1, 2006 07:15 PM
Eg6_JDM
Aug 1, 2002 06:28 PM
