b18c in 4g civic help please!!!!!!!!!!!!
i got a 89 si hatch and i want to or should i say i did put the 94
b18c obd1 in everything mechanical is fine my problem is the wiring if im going to use the grs ecu how do i make it so that it will work ?????? is there a site or does anyone know how to do this i know someone has done this also i know about place racing but they are backed up for months and i unfortunatley cant wait that long this is also my daily driver someone please help post or e-mail me blu98cvc@msn.com
If you are good in wiring up the car then get yourself a helms manual and then connect each wire.. Let me tell you first, wiring up a 94 gsr to a 89 isnt a easy job. Its very hard and time consuming. If you cant wire, then I would sugges you take your car to a good shop and have them wire it up for you. If place racing is back up, and you cant wire for ****, then maybe you should think about get a standalone. Such as haltech or speedpro, dfi etc. If you go with a standalone such as the one i jsut mentioned then you wont use the factory harness. Believe me its a pain to wire up b18c to a 89civic. And you using a cable tranny right? or did you convert your shell to hydro? its going to take time.
eg6hatch
Jul 10, 2003 05:31 AM
