painting a AEM SRI?
Old Sep 10, 2004 | 07:44 AM
sicivic's Avatar
Default painting a AEM SRI?
I didn't know where to post this so I posted here in the Accord forum because the intake is going on a Accord. But has anyone ever painted an AEM SRI or CAI with high-temp black paint. Would this be a bad idea? I get a blue AEM SRI and want to paint it with high-temp black paint to give the engine bay a little bit more a stock look, but just want to make sure its not a bad idea?
Old Sep 10, 2004 | 07:48 AM
propwdialogue's Avatar
Default Re: painting a AEM SRI? (sicivic)
vr has done it. he said it actually helped keep his air cooler so yeah it definitely wont hurt you. all you should have to do is sand it down and spray it
Old Sep 10, 2004 | 07:50 AM
cd5_2NR's Avatar
Default Re: painting a AEM SRI? (propwdialogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">vr has done it. he said it actually helped keep his air cooler so yeah it definitely wont hurt you. all you should have to do is sand it down and spray it </TD></TR></TABLE>
yup...back when i had a hatch my intake/vc/ and heat shield were flat black/temp paint..definitely helps with cooler temp...
Old Sep 10, 2004 | 07:51 AM
Miss Green-Eyes
Guest
Posts: n/a
My b/f painted his but had them sanded down & primed then painted it over with high temperature black flat paint.
Old Sep 10, 2004 | 07:52 AM
asnboi_512's Avatar
Default Re: painting a AEM SRI? (cd_5TUNR)
paint makes air colder?
Old Sep 10, 2004 | 08:37 AM
sicivic's Avatar
Default Re: painting a AEM SRI? (asnboi_512)
I think what they are trying to say that the paint helps keep the incoming air from getting hot because of the extra layer of paint.
Old Sep 10, 2004 | 09:31 AM
BoostedH23Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asnboi_512 &raquo;</TD></TR><TR><TD CLASS="quote">paint makes air colder?
</TD></TR></TABLE>exactly my thought...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicivic &raquo;</TD></TR><TR><TD CLASS="quote">I think what they are trying to say that the paint helps keep the incoming air from getting hot because of the extra layer of paint. </TD></TR></TABLE> that sounds ok in theory but does anybody have an idea of how much cooler. My guess would be that there wouldn't be enough of a temperature change to really make much difference.
my $.02
Old Sep 10, 2004 | 10:26 AM
cd5_2NR's Avatar
no...the paint itself is made to withstand heat...that's why some manufacturers make black mufflers...etc etc...
paint doesnt make air colder it prevents the intake from absorbing some heat...
it doesn't make too much of a difference though...but it helps some
Old Sep 10, 2004 | 01:32 PM
asnboi_512's Avatar
um.. i REALLY doubt this theory.. waste of 4 dollars on a can of paint.. maybe the exaust is made from a differant **** so it absorbs less heat.. i doubt that just because its black it helps..
Old Sep 10, 2004 | 02:50 PM
sicivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asnboi_512 &raquo;</TD></TR><TR><TD CLASS="quote">um.. i REALLY doubt this theory.. waste of 4 dollars on a can of paint.. maybe the exaust is made from a differant **** so it absorbs less heat.. i doubt that just because its black it helps.. </TD></TR></TABLE>
I'm not painting the intake for a cooler intake air. I want to paint the intake so it looks closer to stock and not a bright blue eye sore when you open the hood.
Old Sep 10, 2004 | 04:11 PM
pyrojeff's Avatar
Bought my intake off of ebay, sanded it down, and painted it with regular flat black paint. Works like a charm.
Old Sep 10, 2004 | 04:28 PM
The_Todd's Avatar
Farts in the shower
Well I will tell you this, when my intake was regular metal after running the car for a while i couldn't even touch it but after I painted the tube I could actually hold my hand on the pipe...so as far as hot versus cold its true.
If you have the paint sitting around why not do it...IMO it makes for a cleaner engine bay NTM IS functional .
Just sand down the tube and paint the tube let it dry then reinstall. Here is some pictures of mine:
IMO it makes the engine bay look really clean and the next thing I am painting will be my tower brace. Its all about personal styel and flavor.
edit: sorry for the dirty engine bay
Old Sep 10, 2004 | 06:13 PM
SiK AcC0rD's Avatar
Default Re: painting a AEM SRI? (VRDrvr)
I did it a long time ago....i think the color is graphite grey.
Old Sep 13, 2004 | 11:21 AM
Sec Ceeeeee
hotNsexy69
May 9, 2005 08:26 PM
aburn
Apr 19, 2003 05:08 PM
vtec69
Nov 26, 2002 11:15 AM
RAB
Oct 27, 2002 10:28 PM
RAB
Oct 18, 2002 07:10 AM
