lowering springs question??
Old Sep 9, 2004 | 08:59 PM
#1sandman's Avatar
Default lowering springs question??
[B]My set of Tenzo R lowering springs came today, there suppose 2 give me a 2.0 to a 2.25 inch drop back and front. two of the springs r shorter and the other two are a little bit longer do the short ones go on my front struts or the taller ones???
AND
All 4 springs have a wide base with a kind of flattened bottom and on the other side a smaller coil that is not flattenet but a perfectly round coil. what side should face up when im doing my instalation on my struts the wider end coil or the smaller end coil.
Old Sep 9, 2004 | 09:04 PM
BigDaddy's Avatar
Default Re: lowering springs question?? (#1sandman)
If you're going to the install your self then look at the stock srping for orientation...but the flat end should go on top and the rounded end down...
I'm not 100% sure but the longer srping is in the front and shorter rear...
Old Sep 9, 2004 | 09:12 PM
HARI.'s Avatar
Default Re: lowering springs question?? (BigDaddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDaddy &raquo;</TD></TR><TR><TD CLASS="quote">but the flat end should go on top and the rounded end down...
that sounds about right
Old Sep 9, 2004 | 10:18 PM
JFG Kevin's Avatar
Default Re: lowering springs question?? (deeaye9)
try to figure it out b4 you take out the stock spring, if you dont know then i dont know if it's safe to work on a car you dont know much about. you might get stuck in some areas takin it out. or shot by a spring.
Old Sep 9, 2004 | 11:19 PM
wickedplastikman's Avatar
Default Re: lowering springs question?? (aznstyler119)
listen to aznstyler. i dont know how much experience you have in auto mechanics, but replacing your springs can be dagerous. first of all, you will need a spring compressor so that the spring doesnt shoot out. i have known someone to shoot a spring and make a nice hole in his garage.
Old Sep 10, 2004 | 08:42 AM
GetawayInMoscow's Avatar
Default Re: lowering springs question?? (wickedplastikman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedplastikman &raquo;</TD></TR><TR><TD CLASS="quote">listen to aznstyler. i dont know how much experience you have in auto mechanics, but replacing your springs can be dagerous. first of all, you will need a spring compressor so that the spring doesnt shoot out. i have known someone to shoot a spring and make a nice hole in his garage.</TD></TR></TABLE>
Search on Honda-Tech, I've read a lot of threads on safe ways to do it without a spring compressor, like wrapping it in a huge towel so it has no where to shoot, I think one person even shot his into the gabage can..lol.
Old Sep 10, 2004 | 08:45 AM
GSaargh's Avatar
Default Re: lowering springs question?? (GetawayinMoscow)
when i lowered my car, i had used a spring compressor... kinda pointless. just have a bucket infront of the spring.
i believe that the longer, skinnier springs go in front. good luck
forestcd6
Suspension & Brakes
Jul 3, 2011 02:08 PM
05khbdc5
25
Apr 16, 2008 05:53 PM
HooberSi
Suspension & Brakes
Apr 3, 2006 11:19 AM
str8drift
Mar 29, 2006 04:26 PM
E-lude78
Jan 15, 2003 12:34 PM
