which flywheel does the zc use?
Old Dec 7, 2001 | 04:21 PM
crxnug's Avatar
Default which flywheel does the zc use?
Im rebuilding my zc motor and was wondering which flywheel the zc uses, ,and if anyone could recommended one, clutch masters,tora, spoon
Old Dec 7, 2001 | 04:39 PM
Magick211's Avatar
Default Re: which flywheel does the zc use? (crxnug)
Well it depends on what tranny you are using. If you are using a 90-91 si tranny then use 90-91 si flywheel
Old Dec 7, 2001 | 04:41 PM
crxnug's Avatar
Default Re: which flywheel does the zc use? (CivicBoyZC)
im using the dx tranny
Old Dec 7, 2001 | 05:23 PM
akachef's Avatar
New User
what year..that's important.
i'm a bit confused tho as well. are the flywheels 88-89 and 90-91? or 88, 89-91? cause i had an 89 tranny, so i used my 89 clutch, then when i replaced my clutch i put in an 88 clutch and tranny combo, it still works fine with the zc flywheel though, which i have no clue what year it is.
Old Dec 7, 2001 | 06:23 PM
crxnug's Avatar
Default Re: which flywheel does the zc use? (akachef)
its a 90 dx, and i have a ACT clutch installed when i put the engine in, im hoping the 88-91 crx si one would be the same, i would hate to buy the flywheel and find out its the wrong one later, im buying the parts now and getting it rebuilt in the spring
Old Dec 7, 2001 | 08:20 PM
nikitad's Avatar
your 90 dx flywheel will be just right for the zc and a 90 clutch.
well.. you were talking about aftermarket... go with SI it'll work.
[Modified by nikitad, 5:21 AM 12/8/2001]
Old Dec 8, 2001 | 12:31 PM
89civicdx's Avatar
Default Re: which flywheel does the zc use? (nikitad)
90-91 clutch fits 90-91 civic/crx dx,si flywheels
89 clutch fits 89 flywheels
Dude just go by Leitner and lighten your flywheel I have an extra stock 90 flywheel if you need one.
johnpowellcrx
Oct 5, 2004 09:23 PM
phatrick2332
Mar 31, 2004 06:11 AM
giantdumbass
10
Oct 18, 2003 11:53 AM
Ronin Panda
15
May 11, 2003 05:05 PM
FourthGenHatch
11
Apr 16, 2003 06:43 PM
